what fuel pump r u running?
Old May 14, 2002 | 01:35 PM
Eggman's Avatar
Default what fuel pump r u running?
what are my options for a in-tank fuel pump?
Old May 14, 2002 | 01:48 PM
Doodoo's Avatar
Default Re: what fuel pump r u running? (Eggman)
I run a Walbro, you can use a Supra TT or Eclipse GSX.
Old May 14, 2002 | 01:53 PM
mackymcg's Avatar
Default Re: what fuel pump r u running? (Doodoo)
I'm using an ITR one. After I did my swap my old STD fuel pump lasted about another 6K (152K Total) before it conked out.
Old May 14, 2002 | 02:01 PM
june's Avatar
Default Re: what fuel pump r u running? (mackymcg)
I'm using the holley fuel pump for the 92 and up civic/integras.
Old May 14, 2002 | 02:23 PM
Urban Business
Guest
Posts: n/a
Default Re: what fuel pump r u running? (civicefhatchback)
mustang 5.0L pump
Old May 14, 2002 | 02:35 PM
CRXRageD's Avatar
get an AC delco r32 skyline fuel pump, direct drop in and cycles once every 5 mins. It's badass. I have a giant bosche modified by endyn. It works great.
Old May 14, 2002 | 03:28 PM
Eggman's Avatar
Default Re: what fuel pump r u running? (CRXRageD)
got a part#? is it a better fit than the DC/EG ones?
Old May 14, 2002 | 03:43 PM
ivanED9's Avatar
The Holley 255LHP In-tanks are really nice and will supply enough fuel for almost all applications. But, I am runnin stockA right now
Old May 14, 2002 | 04:04 PM
Eggman's Avatar
Default Re: what fuel pump r u running? (ivanED9)
any company make one for 88-91 applications? or just 92+?
Old May 14, 2002 | 05:31 PM
pelotudo's Avatar
What pump would you guys recommend for a B16a going N/A / N2o? I have heard a 93 Supra 255lb is good, but can't seem to find one. Which ones will hook straight up w/o any problems, and what year/make/model car should I get it from? I work at an auto parts store, and can get any "stock" item...so if I know the year/make/model car I can get it...
jB
Old May 14, 2002 | 06:26 PM
hardware17's Avatar
Default Re: what fuel pump r u running? (PeloTudo)
mustang 5.0.......get the upgraded BBK one in Summit.....theyve got some good stuff
Old May 14, 2002 | 08:10 PM
B16ED4G's Avatar
I am using the walbro 190LPH in my 89 hatch W/B16. I'm spraying 60 dry N2O on it and it works great. Mine was a universal in tank pump, I had to modify the pump bracket a little, so now when my gauge says E, i'm really out of useable fuel, because the pump sits a little higher in the tank, But no bigge, I don't run my tank that low anyway
Chris
VspecSiR
May 17, 2004 04:37 AM
85mm LsVTEC
Dec 22, 2003 10:19 AM
speedyonez
Oct 23, 2003 12:17 PM
