how to identify fuel injectors?
Old Jan 7, 2007 | 08:50 PM
russianswty's Avatar
Default how to identify fuel injectors?
How do I know which plugs I have? If there saturated or not?
Since I bought them used I just want to very.
Or If I put the wrong plugs what could happen?
Old Jan 7, 2007 | 09:55 PM
89efDUSTY's Avatar
Default Re: how to identify fuel injectors? (russianswty)
plugs or injectors? anyways go to FI there is a section in the faq explaining injector info...hope it helps
Old Jan 7, 2007 | 11:01 PM
Default Re: how to identify fuel injectors? (89efDUSTY)
does it matter what plugs im using? as long as I took care of the resistor box.
any ways how do I identify which ones I have without knowing 100% where they
came from.
Old Jan 7, 2007 | 11:37 PM
89efDUSTY's Avatar
you can check the ohms to see if they are saturated or peak and hold...its alot of reading but its in there
Old Jan 10, 2007 | 08:21 AM
do I need to put any power through them when I do that?
Old Jan 10, 2007 | 08:32 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by russianswty &raquo;</TD></TR><TR><TD CLASS="quote">do I need to put any power through them when I do that?
use the multi-meter and see what the resistance is across the 2 conectors
i dont remember the exact numbers but if its around 2 ohms,its peak and hold
if its around 12 ohms,its saturated..ill try and find the exact numbers for you alough you shouldnt need them since theres such a big gap
12
May 12, 2008 07:30 AM
henry86
Apr 13, 2008 06:51 AM
jrs2ksi
Dec 9, 2006 04:48 PM
chad
Oct 27, 2004 06:21 PM
