Building an LS with ITBs
Old Jan 7, 2007 | 06:38 PM
bdavissi's Avatar
Default Building an LS with ITBs
I got a 91 Si with a rebuilt B18a. The internals are all stock as this was a budget build. My question is has anybody done the ITB's on a stock LS with obd-0 and if so, what needs to be done? I have found 2001 GSX-R 600 throttle bodies and want to know what steps I have to take with installing them. o I newed to ochange the ecu (91 integra ecu) or do I have to convert to OBD1? Thank you.
Old Jan 7, 2007 | 06:56 PM
Crx Jimmy's Avatar
Default Re: Building an LS with ITBs (bdavissi)
you might want to go to obd1 for tuning. ITB's are a pain to tune. I dont think you will get any benefit out of a stock motor you would need higher compression and some cams to make power with those ITBs.
Old Jan 7, 2007 | 08:41 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Building an LS with ITBs (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">you might want to go to obd1 for tuning. ITB's are a pain to tune. I dont think you will get any benefit out of a stock motor you would need higher compression and some cams to make power with those ITBs.</TD></TR></TABLE>
I agree ITBS really arn't the best for most cars.
you can do ITBs off turbo edit IIRC but i'm not sure it's been ages since I was obd0.
I know in the all motor forum there are a few write ups how to use bike TBs for a Honda.
If you want to stay budjet LS build some mild cams good header rod bolts and an b16 tranny. I would say the intake manifold is not the first place I'd look for adding power on a LS motor.
siR-E_978
Aug 28, 2009 06:17 AM
bertsb18hatch
Nov 13, 2007 04:33 PM
G MoNeY Ej1
Apr 28, 2007 08:53 AM
hondaguyef
Mid-Atlantic (Sales)
15
Oct 21, 2005 06:49 PM
See Are X
Apr 18, 2002 10:49 AM
