ac bearing going out
Old Jan 7, 2007 | 06:16 PM
justseeingifitistaken's Avatar
Default ac bearing going out
anyone ever had any luck replacing the ac pulley bearing....went to some ac shops and they said that it can not be done on a sanden compressor? also if the bearing were to lockup could it possibly snap the timing belt or make it skip time? thanks
Old Jan 7, 2007 | 06:28 PM
umop-apisdn's Avatar
Default Re: ac bearing going out (hondaJDMimports)
Your AC doesn't run off the timing belt, each system has it's own. Don't know if the bearing can be replaced or not.
Old Jan 7, 2007 | 06:30 PM
Got_soy's Avatar
My A/C bearings locked up on me, first it squealed, then smoked. I just pulled it out when i did my swap. Nothing too bad can happen, you'll just have to get a new belt& compressor
Old Jan 7, 2007 | 06:36 PM
Default Re: ac bearing going out (Got_soy)
i know that it is on a separate belt and all but a complete lock up was the concern.....i guess i am just being paranoid about it cause it is my wife's car and dont want to hear it if breaks down.
Old Jan 7, 2007 | 06:54 PM
Crx Jimmy's Avatar
no, if it locks up the motor will keep spinning and the belt will burn till it breaks, you will smell a god awful smell if it starts to lock up. just replace the idler as a whole its not that expensive
Old Jan 7, 2007 | 07:11 PM
Default Re: ac bearing going out (Crx Jimmy)
well i dont think it is the idler itself, it is the compressor pulley. i already replaced the idler. i originally thought it was the compressor but i oiled the poopy out of it and it still makes the noise like crazy. there is a separate bearing for the pulley correct?? thanks
Old Jan 7, 2007 | 07:31 PM
onepoint6i's Avatar
sounds like your compressor is the culprit..you need to replace the whole thing..either that or just remove the belt..
Old Jan 8, 2007 | 08:29 PM
Default Re: ac bearing going out (onepoint6i)
one more question and i promise ill stop.......the a/c clutch, does it have a bearing possibly???? thanks
chieftaco
10
Oct 11, 2009 03:38 PM
typecastaaron3
Honda Civic (2001 - 2005)
May 22, 2008 08:56 PM
sinister357
Jul 28, 2007 06:36 PM
markysparky
21
Oct 30, 2005 08:03 PM
ackerjack
Jul 29, 2004 09:42 PM
