Offset, and tire question?
So I did a search, but couldn't find a solid answer. I drive a '90 CRX Si, the car has a 2" drop, and I'm running roughly -1.5 degrees of camber. I'm planning on buying some 15x7 wheels with a +40 offset. Can I safely run a 205 width tire, or will I have rubbing issues? Should I just stick to 195's.. I have 15x6.5 wheels right now, but they have a +35 offset, and 205's rubbed on those wheels. Any help would be greatly appreciated, thanks!!
Mike
Mike
more than likely your gonna rub, why dont you just roll your fenders? on my 88dx i have a 3+ inch drop on 15x6.5 w/205/50's with a +32 offset..i have no rubbing issues.. my camber is @
-2.5 rear -2.0 front..my front/rear fenders are rolled...
either
a:roll your fenders
or
b:add more negative camber (inner tire wear is not an issue, especially with scheduled wheel rotations)
BTW: ive ran 15X7 with a +35offset 205/50's also.. no rubbing whatsoever either..
either
a:roll your fenders
or
Thanks for the solid answer. It's much appreciated man. I had 205 Falken Azenis on my 15x6.5 rims, with a +35 offset, and @ -1.5 degrees of camber, rolled fenders, and it rubbed pretty bad. Pretty much, my best option would be to dial in more negative camber, but I have to be honest, my current camber setup really prolongs my tire life, and I commute daily in my CRX. I think i'm just going to run a 195 width tire on my new wheels. Thanks again man!
Mike
Mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeFabRex »</TD></TR><TR><TD CLASS="quote">Thanks for the solid answer. It's much appreciated man. I had 205 Falken Azenis on my 15x6.5 rims, with a +35 offset, and @ -1.5 degrees of camber, rolled fenders, and it rubbed pretty bad. Pretty much, my best option would be to dial in more negative camber, but I have to be honest, my current camber setup really prolongs my tire life, and I commute daily in my CRX. I think i'm just going to run a 195 width tire on my new wheels. Thanks again man!
Mike</TD></TR></TABLE>
sounds ideal
sounds ideal
