will accord rims fit my civic
Hey all! I was curious to find out if accord rims would fit my 95 civic ex? I would be getting them for a really good price, but I want to make sure they will fit, they are 15's w/ a four bolt pattern.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importnoodles »</TD></TR><TR><TD CLASS="quote">how the heck can a SPACER change ur lugs from a 4x100 to 4x114?</TD></TR></TABLE>
Magic.
Magic.
mackin industries makes special conversion spacer.
4-100 to 4-114.3
5-100 to 5-114.3
4-100 to 4-114.3
5-100 to 5-114.3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head »</TD></TR><TR><TD CLASS="quote">got a link to this conversion spacer thingamagig?</TD></TR></TABLE>
i looked on there website didnt have them on there but they have a ad in the Super street October issue on page 97.
http://www.mackinindustries.co....html
They have conversion ones, and they also let you run big brake kits without 17" wheels.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi »</TD></TR><TR><TD CLASS="quote">wouldnt trust that **** IMO</TD></TR></TABLE>
Dunno, it's made by Mackin, not OBX
after seeing what spacers do to your wheel bearings, i wouldnt trust something of that magnitude. It looks like it pushes the offset so far out just to cover up the existing studs, so the wheel can fit flush with the conversion. Say bye bye to your bearings if you drive on bumpy roads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi »</TD></TR><TR><TD CLASS="quote">I agree, Id rather do a 5 lug conversion ANY day of the average womans menstrual cycle</TD></TR></TABLE>
uhh what
uhh what
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YoungKadafi »</TD></TR><TR><TD CLASS="quote">after seeing what spacers do to your wheel bearings, i wouldnt trust something of that magnitude. It looks like it pushes the offset so far out just to cover up the existing studs, so the wheel can fit flush with the conversion. Say bye bye to your bearings if you drive on bumpy roads.</TD></TR></TABLE>
So having a spcer is bad eh? Cuz my lilttle bro bought some HX rims for his EX and had to get spacer because the caliper/brakes was bigger than the HX. Anyways so spacer is bad in all case or what's up? Got me thinking.
it puts stress on the hub, the wider the track on your car *front* i think the more your suspension takes a beating when going over bumps. And i wouldnt do a spacer on the HX's, id rather shave the caliper bracket down a few mm's. Also the stress on the wheel studs is added unless you have APR extended studs.
Read up on wheel spacers, i did for months before i was detered from them, NEVER to purchase some in my lifetime.
Same goes for the 4x100 to 4x114, thats even worse, just common sense, put some on your car then tell me what you think? however if you are drag, then its up to you, but a DD and autox, you will be sorry. Wheels are suspension arent something to F around with if you get my drift
