quick identification question
Old Jan 7, 2007 | 04:49 PM
Rhythmsnewsn's Avatar
Default quick identification questions
well as you all know i smashed a curb before xmas and royally messed up the ride. well im not too sure if im going to fix it or not but i need some things cleared up before i do, here is a pic of the damage, i know it needs an axle but in bubbles 1-3 are other known problems. bubble 1 i have no idea what it is but it "was" connected to the control arm, bubble 2 i have no idea what it is at all and bubble 3 is my caliper, all of a sudden its leaking ALOT of brake fluid and im not sure if i popped a hose or whatever but the main questions are... in bubble 1 is that the subframe or something? is my car worth fixing? is there a way that part can be unbolted and swapped?
Old Jan 7, 2007 | 07:57 PM
Default Re: quick identification questions (Rhythmsnewsn)
bump
Old Jan 7, 2007 | 08:01 PM
italionstallion888's Avatar
number 2 looks like the radius ram from the front cross member, but I might be wrong
Old Jan 7, 2007 | 08:27 PM
ricecooker415's Avatar
^ right
it might be owrth fixing if you can get a cheap rear sub frame for cheap along with the radius. but i would make sure ntohing else is bent first
tekstyle
Suspension & Brakes
Aug 21, 2009 07:43 PM
karkrazy9
Jun 22, 2008 03:52 PM
evo1234
Suspension & Brakes
Feb 15, 2006 07:14 PM
Mike Ockhurts
Honda Motorcycles
Nov 19, 2005 06:58 PM
Isaac
Mar 25, 2002 11:32 AM
