turbo help need info for relible setup's
Old Jan 7, 2007 | 03:31 PM
adam squared's Avatar
Default turbo help need info for relible setup's
hi all you ht guys need some help i just got a 96 gsr db8 and wanted to know how to set up a super relible turbo set up , in other words it's my daily driver and i need to know what componets are needed or what set up's are relible for 300-400 hp the car is bone stock, i know the tune has a big prt in it , but i need relible comforitble drivability as this again is my daily driver, thanks in advance .
Old Jan 7, 2007 | 03:33 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: turbo help need info for relible setup's (adam squared)
Rebuild the block
Get some Wiseco forged pistons low compression
Eagle h Beam ROds
Arp studs/bolts
Oem hg
Walbro 255lph
Get turbonetics or Garrett
Get some Rc 750cc injectors depending on your setup
Old Jan 7, 2007 | 03:47 PM
Default Re: turbo help need info for relible setup's (PnoyEj6)
so while rebuilding the block should i resleave the block with benson sleev's or should i just stick with stock sleev's
kcfoodsci
Aug 18, 2016 08:51 AM
Thegreenlude
Jul 4, 2010 02:04 AM
Nigtflyer
Mar 17, 2007 09:27 PM
xxx92vtechatchxxx
May 22, 2006 12:53 PM
