engine rebuilding
Old Jan 7, 2007 | 03:08 PM
ge_itr's Avatar
Default engine rebuilding
i'm planning to build my h22a1 block. i need some suggestions. i want to go all motor. planning bore size 89mm,100mm stroke, with 12.0:1 compression ratio.
my first option is sending the core to exospeed and have them rebuilt it for $4300(stage 4 max).
second option is send it to pocketrocket for $4895(na block package).
third option is buy darton mid sleeves ($625) with na stroker kit from pocketrocket ($3478) and have a local machine shop install it($?).
fourth option is send it to pocketrocket, exospeed, or goldeneaglemfg for sleeving services (about $850, exospeed)and buy darton sleeves($625) and the stroker kit($3478) from pocketrocket or buy pistons, rods, crank separately($?) for local installations($?).
which one do you guys thank is best? or a combination? i'm trying to have a balance between price and quality.
Old Jan 7, 2007 | 03:39 PM
98vtec's Avatar
moderator emeritus
Default Re: engine rebuilding (ge_itr)
wouldnt 100mm of stroke require either a deck plate or offset boring cuz thats a shitload of stroke.
i believe you would also need to get the block notched so the rods have room to travel.
i'd go with Frank (pocketrockets) on this one.
Old Jan 7, 2007 | 04:55 PM
ge_itr's Avatar
pocket rocket says it's possible. but they're about $500 more than exospeed. does anyone know how long they usually take for this kind of build?
anyone else?
Old Jan 7, 2007 | 05:01 PM
98vtec's Avatar
moderator emeritus
Default Re: (ge_itr)
of course it can be done but making a block run 100mm of stroke is no task i would let someone who hasnt done it before, do it.
bapecivic
Sep 13, 2013 09:13 AM
masonracing
Oct 17, 2011 06:37 PM
ALLOUT CL55
Northern California (Sales)
20
Jan 8, 2007 05:01 PM
ge_itr
Jan 7, 2007 04:58 PM
EVOCELICA
Feb 25, 2003 11:26 AM
