Fog light wiring?
Old Jan 7, 2007 | 02:22 PM
turnsignalandy's Avatar
Default Fog light wiring?
Just orderd some square fogs for my ek. I got the ones of passwordjdm, i think their depo. However I am wondering how to wire them so that I could turn them on all the time not just with the low beams?
Old Jan 7, 2007 | 02:23 PM
Eran's Avatar
HT White Ops
you just pick one of the accessory ports that is not low-beam dependent.
Old Jan 7, 2007 | 02:24 PM
BlueIntegraBoy's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">you just pick one of the accessory ports that is not low-beam dependent.</TD></TR></TABLE>
Yes, like a slot that is hot at all times
Old Jan 7, 2007 | 02:33 PM
Default Re: (BlueIntegraBoy)
k thanks. This will be my first wirring jobs, and im probably gona have a more experianced friend help me. But how do I know if the slot is hot or not?
Old Jan 7, 2007 | 02:36 PM
john666's Avatar
Default Re: Fog light wiring? (turnsignalandy)
there are only 5 slots so just plugging it in and turning it on shouldnt be that big of a thing
Old Jan 7, 2007 | 02:40 PM
Default Re: Fog light wiring? (john666)
many thanks for all ze help.
Old Jan 7, 2007 | 02:43 PM
Default Re: (turnsignalandy)
#1 is hot all the time. So you can have your fogs on without your car being on.
I suggest sticking it into #3 or #4, so when your key is in those positions, the fogs will work.
You know what? The Depo kit is indepedent on the headlight switch, meaning you don't need your parking lights or headlights for them to work.
I wired Depos to my friend's car and he could turn them on whenever he wanted.
Old Jan 7, 2007 | 02:56 PM
so stick ot number 3 or 4 or else if i plug them into 1 I could forget to turn the fogs off and they would stay on without the key in the ingnition.
Old Jan 7, 2007 | 02:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">so stick ot number 3 or 4 or else if i plug them into 1 I could forget to turn the fogs off and they would stay on without the key in the ingnition. </TD></TR></TABLE>
If you stick them in #1, you run the risk of draining your battery if left on (and forgotten).
Old Jan 7, 2007 | 03:01 PM
allricedout's Avatar
i also plan on getting some...there tyte
Casey
Jun 12, 2007 03:31 PM
shifts
12
Oct 16, 2006 10:36 AM
EK Josh
Jul 26, 2005 09:38 AM
B18C-VTI_R
Jul 13, 2004 07:00 AM
