Engine codes & Battery light...
Hi everyone, I'm the new owner of an '90 Civic Si and find the car to be a joy to drive but I have a few problems. First off, whenever i rev over 5.5-6k (in gear or not) the battery light goes on and stay on until the rpm drops around 4.5-5k. Now i get two codes from the ECU (4 & 9), respectively the TDC and 1st piston position sensors.
I think both problems are related, but the ECU codes point in the direction of a faulty distributor, while the battery light leans towards the alternator. The car always runs fine, like there's no problem at all...
Any thoughts?
Thanks in advance
Any thoughts?
Thanks in advance
Yes, the 4 and 9 would indicate a distributor problem. Take the cap off and check for red dust. If there's a lot of it, it could be a sign of a failing distributor bearing. The dust may be interfering with the sensors.
Just a guess about the battery light. Maybe reving makes the worn out brushes skip enough to reduce the output and trigger the light?
ElCivic89
Jul 6, 2015 03:48 AM
rattlecannedEF
12
Apr 2, 2009 06:53 AM
