Can't find the Transmission Drain
Old Jan 7, 2007 | 01:21 PM
PrettyFastRide's Avatar
Default Can't find the Transmission Drain
Hey I am working on my automatic Honda accord 96 and I can't figure out where to drain my fluid, I can't find the bolt for it. If someone could show me pictures or some information that be great. THANKS
Old Jan 7, 2007 | 01:58 PM
philadd's Avatar
Default Re: Can't find the Transmission Drain (PrettyFastRide)
Look for a plug that has a square hole... A ratchet will insert into it (with no socket). It should be facing the passenger side, on the bottom of the transmission of course.
Old Jan 7, 2007 | 04:54 PM
The-Kid's Avatar
Ummm to add more to the philadd said, I suggest taking out the front passenger wheel(easier) and fit a 3/8 rachet in there. You might need some strength. =D Make sure you got a pan ready! Good luck!
Old Jan 7, 2007 | 05:20 PM
lunarone's Avatar
just jack it up and look under the passenger side wheel well, 3/8th square bolt, pop it loose and let it flow.
Old Jan 7, 2007 | 05:42 PM
Thanks guys, I found the square bolt, Now I need to know how many quart to fill up the transmission.
Old Jan 7, 2007 | 05:47 PM
02 accord's Avatar
Default Re: (PrettyFastRide)
About 2.5 quarts.
JDM-LuxurySport
May 6, 2010 07:30 AM
.inbou
Nov 6, 2009 01:42 PM
ocdcivic
Dec 11, 2004 10:11 AM
mnbv
Aug 1, 2004 11:51 PM
Mr Samson
Jul 2, 2003 05:06 PM
