Dead civic
Old Jan 7, 2007 | 09:48 AM
riceburnerex's Avatar
Default Dead civic
I have a 1999 Civic EX that has died on me. Long story short my synthetic oil was gone and I think it spun a bearing on the bottom end to start with, then I tried to get the car home after putting more oil and oil lubricant in it. after about 20 miles the car lost all power and 20 mph on interstate was all it would do. After stopping I fired it up again and it sounds like pure metal raking inside the motor. I know i screwed it up but now I am wondering if it would be best to try a rebuild or just buy another motor. Also I am wondering how I can tell which engine I have in my car. I have seen d15, d16, b16, h22 just to name a few.
Old Jan 7, 2007 | 09:50 AM
MasterKwan's Avatar
Default Re: Dead civic (riceburnerex)
Cheaper probably to find another motor.
Old Jan 7, 2007 | 09:59 AM
gezzuzz's Avatar
Default Re: Dead civic (MasterKwan)
get another d16y8
Old Jan 7, 2007 | 10:01 AM
So I have the d16y8 engine?
Old Jan 7, 2007 | 10:02 AM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: Dead civic (gezzuzz)
another y8 if you wanted back to stock ..but what are you trying to get out of your car as far as goals? that would help as well
Old Jan 7, 2007 | 10:05 AM
The car is an everyday driver that I have only done visual upgrades to the outside. I am just looking to find the cheapest and best way to go.
Old Jan 7, 2007 | 10:06 AM
bart2546's Avatar
I have the same car, if you didn't do anything with it, you should have a D16Y8 in it, but to check if you look on the tranny to the left of the header and on the engine block (still in the front but don't remember where) you can see the code for the engine.
I believe it's somewhere in the area that I circled.
EDIT* A new Y8 should only cost a couple hundred for another motor, that's NOT including install.
Old Jan 7, 2007 | 10:08 AM
gezzuzz's Avatar
call local motor swap shops.. likely they have a d16y8 from someone swaping it out for a better motor.. you can get them $400-600.. and because its a stright forward swap should cost $400-600 to install (if you can;t get it done yourself)..
Old Jan 7, 2007 | 10:26 AM
97civicdx's Avatar
99EX's have the D-16Y8. 127 hps.
cx/dx's have the D16Y7 with 109 hps.
Get a B-16 or B-18 swap.
Old Jan 8, 2007 | 09:01 PM
dnkksEJ's Avatar
dnt do a y8 again.. pik up a odb2 ls long block and an b series tranny u can find... and do a full swap youl have more fun with it
Old Jan 8, 2007 | 09:07 PM
TurbdEG6's Avatar
Default Re: Dead civic (dnkksEJ)
he said the cheapest and best way to go...not or b16 or b18. it doesn't seem like he wants to put more into it than he has to. Just get another d16y8. It will install quickly and easily, and it won't break your wallet.
Curlybandit
Mar 30, 2008 05:47 PM
inane
15
Sep 13, 2004 07:36 PM
honda9369
15
Jun 11, 2004 08:45 AM
BUGGA
May 15, 2004 11:09 AM
