how to remove aluminum oil pan?
Old Jan 7, 2007 | 09:45 AM
Propulsion's Avatar
Default how to remove aluminum oil pan?
so this thing is like hondabonded shut... there are 2 bolt holes on the bottom and side of the pan, do I run bolts through and just tighten the hell out of it? I've tried prying but I can't even get anything in between the pan and the block and Im afraid of messing up the mating surface.
Old Jan 7, 2007 | 10:31 AM
117's Avatar
117
Is this a 5Gen? What we've found that works best is to remove all the bolts for the oil pan and engine stiffener, and don't forget the two nuts for the oil pan. Remove the engine stiffener, and put some flat stock between the engine stiffener and the block. Then install the bolt between the engine stiffener and the oil pan. Tighten it some, and the oil pan should separate from the block without too much trouble. It's the best method I've found.
Old Jan 7, 2007 | 07:35 PM
Propulsion's Avatar
Default Re: (117)
by flat stock, you mean wood?
Old Jan 8, 2007 | 02:35 AM
117's Avatar
117
Wood, metal, whatever. You only need something 3/16" to 1/4" thick.
Old Jan 8, 2007 | 06:07 PM
Toanz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">Is this a 5Gen? What we've found that works best is to remove all the bolts for the oil pan and engine stiffener, and don't forget the two nuts for the oil pan. Remove the engine stiffener, and put some flat stock between the engine stiffener and the block. Then install the bolt between the engine stiffener and the oil pan. Tighten it some, and the oil pan should separate from the block without too much trouble. It's the best method I've found. </TD></TR></TABLE>
Can you further explain this? I'm a bit confused. I'm trying to take mine off as well but having problems.
Maybe some pictures?
Engine stiffner?
Old Jan 9, 2007 | 03:49 AM
PrecisionH23a's Avatar
Default Re: (117)
He means the aluminum plate that covers the flywheel. Remove it. Then put the 14mm bolt into one of the threads for the flywheel cover. Then use that bolt to pry with wood. That or use a rubber mallet to knock the oil pan somewhat loose. Some of the 5th gens are a real bitch to remove.
cloud7
Apr 9, 2010 08:47 PM
HyphyBB6
Apr 13, 2009 05:18 PM
vectorsc
Mar 31, 2008 06:26 PM
silverskateEF9
Mar 6, 2008 06:48 PM
92hondalude
Sep 27, 2005 09:26 PM
