obd1 crank position sensor?
Old Jan 6, 2007 | 08:56 PM
killerpenguin21's Avatar
Default obd1 crank position sensor?
is there one? im doing a motor build form the ground up and im wondering if i need to get a cps? it will be an obd1 setup put in an obd2 car running a chipped ecu on crome...
thanks!
Old Jan 7, 2007 | 03:55 AM
god.loves.ugly
Guest
Posts: n/a
Default Re: obd1 crank position sensor? (killerpenguin21)
yes. there is a CPS it's in the distributor as far as I know.
Old Jan 7, 2007 | 06:20 AM
TurBoTeG's Avatar
no there is no CPS attached to the oil pump on obd1
Old Jan 7, 2007 | 06:55 AM
Default Re: (TurBoTeG)
so putting the obd1 setup in the obdcar/harness i just leave that plug off and run the obd1 ecu?
sumoneEK
25
Nov 2, 2010 07:55 AM
integranator
Jan 23, 2008 10:03 AM
streetcartuner
10
Jan 6, 2008 08:51 AM
VeronasDead
Oct 10, 2006 01:56 PM
JDM96SpecCTR
Mar 5, 2005 11:03 AM
