Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
clutch went out
Old Jan 6, 2007 | 08:47 PM
Tu MaDre's Avatar
Default clutch went out
40mph in 3rd gear. d17a2
finally went out on me. but, luckly it was down the street from home.
should i do a kswap or just fix it?
3rd gear haves bad synchros or something. almost all the gear's are mess'd up too..
money isn't an option if convinced.
Old Jan 6, 2007 | 08:52 PM
Boilermaker1's Avatar
Ummm a clutch is maybe 300 bucks in parts, and you can get an entire tranny for about the same.
So fix the car for 600 bucks, or swap a motor for almost 6000?
Hell, if it was me, I'd drop a clutch and tranny in it. Its routine wear and tear.
Old Jan 6, 2007 | 08:57 PM
Tu MaDre's Avatar
fair enough. would anybody know where i could view a schematic of the motor/tranny.
Old Jan 7, 2007 | 09:54 AM
Tu MaDre's Avatar
i wasn't the driver. my bro, was driving and I was riding passenger while he was downshifting from 3rd to 2nd he said.. he felt and heard something snap (we figure the clutch cable snap) & it reak'd like hell..
Old Jan 7, 2007 | 09:59 AM
bravo831's Avatar
Default Re: (Tu MaDre)
k20a3 is pretty cheap
Old Jan 7, 2007 | 10:00 AM
Newborn_'s Avatar
Grace Under Pressure
If it reeked like hell (always a good indication of bad wear or a bad driver) and it happened on a downshift, you've probably roasted your friction plate, either through wear and tear and that downshift broke the camels back, or your bro was being rough with it.
You might find the tension springs on the clutch friction plate have lunched themselves.
Old Jan 7, 2007 | 10:04 AM
Tu MaDre's Avatar
i don't know. i think i'd be better off to pull the stock motor at a junk yard. hope i could find one. bravo831 there no carb legal turbo kit for the a3, i've seen one for the a2 but not a3. i would like to do the swap. but, i'm beat by the end of the week.
Old Jan 7, 2007 | 04:35 PM
Tu MaDre's Avatar
i want to pull some serious number's with an a2 even if it's illegal in c.A. my second car is going to be a cb7. I just find the a2 more better to work with, and any k motor would be faster then a d17. but i plan to have a two set up's for an k20a2. 1st set up will be legit, 2nd set up WON'T.
when i complete my 1st set up for my em2, plan to work with a cb7. Then go back to my em2 and build some more serious power. i would like to skip the 1st set up. But, there's alot of reason's why & don't want to get into detail's right now.
I still need a diagram schematic of my d17-a2. motor/tranny
Modified by Tu MaDre at 8:45 PM 1/7/2007
Old Jan 7, 2007 | 04:52 PM
bravo831's Avatar
you dont have to vturbo the a3 you can just i/k/e it will forsure be faster then the stock d17
Old Jan 8, 2007 | 02:31 AM
Tu MaDre's Avatar
~bump~
Old Jan 8, 2007 | 05:33 AM
TN90accord's Avatar
Are you going to try to put a K in a cb7? I looked around for mounts for that a while back and found nothing. It would be a really hard swap. If you didn't mean you were putting a K into a cb7 sorry. Anyways, if money isn't an option if you're convinced, then get the K because you will love it, if you love power and speed. If I had the money I'd have a K swap.
Old Jan 8, 2007 | 05:36 AM
Tu MaDre's Avatar
sorry, u have me mistaken. i want the k in my em2, h22 in my future cb7. i'm lookin for a 90-93 4dr EX cb7 by spring or SO00ON!
Old Jan 8, 2007 | 08:20 AM
blouisgod's Avatar
how many miles on the car? Im at 68k with the stock clutch on my 2k1, but the exedy and flywheel are in the closet just in case.
Im in the same boat with the trans, my input shaft is gone. You should be able to find a decent MT at the yard around your area, about 3-400 buks.
Old Jan 8, 2007 | 01:48 PM
speedracer209's Avatar
Default Re: (blouisgod)
1. D series trannys SUCK
2.K20A3 is the cheapest swap can be done for under $3500 if you know what you are doing
3.a good clutch/flywheel and tranny set up will probally run you into almost the $1000 mark but in the end it will still be a D series. just go K.
Old Jan 8, 2007 | 04:31 PM
Sfedai0's Avatar
Maybe some of you guys abuse the tranny or something. Im at 83K and I dont drive like a granny but my tranny is still smooth. I also have an 01. Changed the fluid at 60k and never slam in to gears.
globy123
Jun 20, 2008 10:54 AM
dan89crxsi
35
Oct 25, 2004 03:17 PM
reeder321
12
Dec 31, 2003 07:29 AM
RJL
Nov 28, 2003 11:25 AM
vteckiller
Apr 11, 2002 08:15 PM
