GSR OIL PAN ON B18A1 BOTTOM END... HELP
Old Jan 6, 2007 | 08:32 PM
xxmikexx206's Avatar
Default GSR OIL PAN ON B18A1 BOTTOM END... HELP
im doing an ls integra swap to my civic eg.... im using b18a1 block with type r and gsr internals.. my question!! im using a gsr bridge and maincaps, do i need a gsr oil pan and baffle etc???? any help is appreciated thanks
Old Jan 6, 2007 | 08:38 PM
gezzuzz's Avatar
Default Re: GSR OIL PAN ON B18A1 BOTTOM END... HELP (xxmikexx206)
you using the gsr main caps on the ls motor?
you can;t do this unless you have it lined bored
motor will fail
Old Jan 6, 2007 | 08:50 PM
Luserkid's Avatar
Default Re: GSR OIL PAN ON B18A1 BOTTOM END... HELP (gezzuzz)
Yea why are you using GSR mains if your using a LS block, you should use LS mains and align bore that.
As for the oil pan its the exact same as an LS except GSR has baffles and LS/B20 dont.
Old Jan 6, 2007 | 08:52 PM
gezzuzz's Avatar
Default Re: GSR OIL PAN ON B18A1 BOTTOM END... HELP (Luserkid)
if yuo use a gsr oil pan you need the gsr oil pick up..
same with the ls pan
if yuo using mixed matched main caps your are asking for big troble
this applys for rods too!!!
Old Jan 6, 2007 | 09:12 PM
KillerBee18's Avatar
as far as using a GSR girdle on a LS you need GSR main studs that are longer and also need the oil pick up, sump, and oil pan for the extra clearance for the girdle. Align hone is recommended if using a girlde on a LS bottom.
Old Jan 7, 2007 | 12:33 AM
Default Re: GSR OIL PAN ON B18A1 BOTTOM END... HELP (KillerBee18)
i am using the gsr main caps and bridge on the ls bottom end... i already got the motor line bored and the rods re-surfaced... as far as the baffle etc... does it need to be gsr or can i just use the ls oil pan etc...
Old Jan 7, 2007 | 01:19 AM
Targa250R's Avatar
be professional
You should probably be asking this in the Integra, Hybrid, or All Motor forums - because this has nothing to do with '92-00 Civics or del Sols.
Old Jan 7, 2007 | 07:34 AM
my_slow_civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">
As for the oil pan its the exact same as an LS except GSR has baffles and LS/B20 dont. </TD></TR></TABLE>
Not to mention the GSR uses a crank girdle, and a different pickup tube. So, that makes the GSR oil pan a wee bit different than the LS.
Old Jan 8, 2007 | 09:08 AM
crxfornow's Avatar
Default Re: GSR OIL PAN ON B18A1 BOTTOM END... HELP (my_slow_civic)
if you use the gsr girdle than you need the pickup tube and the oil pan the gsr pan is different because it is larger to clear the girdle and the pickup goes with the pan so theres your answer
93egSLEEPER
Sep 27, 2009 07:05 PM
lurkin' eg
Feb 18, 2008 07:15 PM
esoterEK..
Feb 22, 2007 09:36 PM
SLOW EF8
Jul 17, 2003 04:14 AM
l
Jul 31, 2002 02:36 PM
