Just installed ITR cams, idle is weird...
Old Jan 6, 2007 | 07:05 PM
keys's Avatar
Default Just installed ITR cams, idle is weird...
Actually, I did a timing belt/water pump replacement as well as installation of ITR cams and skunk2 cam gears. Here's the after install symptoms I'm noticing.
-greyish smoke coming out in puffs from the exhaust
-bumpy idle (from normal to almost stalling to normal again)
-after applying some gas, revs go down and almost stall the engine, but manages to slowly come back up
Cams are set to (0, 0) and I plan to get my Hondata installed and dyno tuned, but I don't want to drive the car in this condition if there's something I must fix first. After researching information on ITR cams, I was under the impression that since these cams are only slightly more agressive than GSR cams they should be daily drivable and just as reliable since it is technically OEM.
Any ideas on what could be causing the problem?
Background specs to help...
94 GSR
183,000 miles
valve adjustment done
timing checked
Recently installed NEW: spark plugs, dist. cap/rotor, radiator, thermostat, belts, hoses, timing belt, water pump
Old Jan 7, 2007 | 12:05 AM
1badteg's Avatar
have you upgraded your valve springs? maybe the valve seals are going with the new cams in.
Old Jan 7, 2007 | 03:10 AM
spoolinfool's Avatar
Default Re: Just installed ITR cams, idle is weird... (keys)
check your cam timing crank timing.Maybe adjusted valves too tight.Plug wires in the right firing order.Reset your ecu and let it idle for a bit.You know we always mess up on the simple stuff.
Old Jan 7, 2007 | 09:14 AM
95 integra's Avatar
Default Re: (1badteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1badteg &raquo;</TD></TR><TR><TD CLASS="quote">have you upgraded your valve springs? maybe the valve seals are going with the new cams in.</TD></TR></TABLE>
What difference do the valve springs make? The valve seals going out at the exact time that he put in new cams and going from good to bad overnight? Unlikely.....valve seals smoke alot at idle and the smoking goes away after idle. My guess is, either your cam timing is off or you might have the TPS and MAP sensors plugged in backwards.
Old Jan 7, 2007 | 09:43 AM
projectTeG's Avatar
Default Re: (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">What difference do the valve springs make? The valve seals going out at the exact time that he put in new cams and going from good to bad overnight? Unlikely.....valve seals smoke alot at idle and the smoking goes away after idle. My guess is, either your cam timing is off or you might have the TPS and MAP sensors plugged in backwards. </TD></TR></TABLE>
+1
Old Jan 7, 2007 | 07:20 PM
keys's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">My guess is, either your cam timing is off or you might have the TPS and MAP sensors plugged in backwards. </TD></TR></TABLE>
Well, I didn't disconnect the TPS or MAP sensors so I'm sure that wouldn't be it. When you say cam timing what do you mean? You mean the settings on the adjustable cam gears? At the moment they are attotally stock settings (0,0). If you mean timing, I do notice something weird about the timing. When I shot the timing belt with a timing light the marks are way off. It is way off to the point where even if I adjusted the distributor to the max to get the marks close to the TDC mark on the lower timing belt cover it's still a good 1/2 inch away still. What can cause the timing to be off that much?
I will try adjusting the valves using the larger of the 2 feeler gauges just in case I might have set them too tight.
Old Jan 7, 2007 | 07:34 PM
95 integra's Avatar
Default Re: (keys)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keys &raquo;</TD></TR><TR><TD CLASS="quote">
Well, I didn't disconnect the TPS or MAP sensors so I'm sure that wouldn't be it. When you say cam timing what do you mean? You mean the settings on the adjustable cam gears? At the moment they are attotally stock settings (0,0). If you mean timing, I do notice something weird about the timing. When I shot the timing belt with a timing light the marks are way off. It is way off to the point where even if I adjusted the distributor to the max to get the marks close to the TDC mark on the lower timing belt cover it's still a good 1/2 inch away still. What can cause the timing to be off that much? </TD></TR></TABLE>
I dont mean the marks on the cam gears, I mean its a tooth off on the cam gears....which can also effect your ignition timing. Thus, even though your gears are set to 0,0 one of them is a tooth off causing it to be off.
Old Jan 7, 2007 | 11:09 PM
keys's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">I dont mean the marks on the cam gears, I mean its a tooth off on the cam gears....which can also effect your ignition timing. Thus, even though your gears are set to 0,0 one of them is a tooth off causing it to be off.</TD></TR></TABLE>
Ok, I'll check that out tomorrow and give you an update. Thanks for the help so far!
Old Jan 8, 2007 | 08:32 AM
Nors's Avatar
Your cam timing is off by a tooth or two. I know its already been said, but it is defintily your problem.
Old Jan 8, 2007 | 10:30 PM
keys's Avatar
Default Re: (Nors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nors &raquo;</TD></TR><TR><TD CLASS="quote">Your cam timing is off by a tooth or two. I know its already been said, but it is defintily your problem.</TD></TR></TABLE>
Nors and 95 integra are exactly correct. I was 1 tooth off. I lined up the side marks a little too low and slightly retarded the exhaust cam while slightly advancing the intake cam. After fixing it, I was also able to adjust my timing to 16 BTC and the idle is perfect!
I just hope the little mistake didn't do too much damage when I ran the engine off spec. Thanks for all the help!
Old Jan 9, 2007 | 05:02 AM
Nors's Avatar
Cool that you fixed it, I wouldn't worry about any damage.
LeBleu Si
Jun 9, 2009 07:20 AM
Fat Chick Magnet
31
Sep 4, 2008 01:57 PM
90HatchSTD
Jul 26, 2004 05:40 AM
shingles
Feb 16, 2004 03:57 PM
Buckshot
Dec 22, 2002 01:12 PM
