Brake upgrades
Since EF(ED)'s can easily transplant EG front and rear disc brakes, we can easily install Spoon or Endless brake upgrades, right? I know these systems are expensive I'm just stating a possibility. Anyone got feedback on this?
Yes it's possible to use the spoon Calipers.......and 98 Spec and up 5 lug Disc's re-drilled to a 4x100mm ... . . .you just have to use a 5mm spacer and longer studs...and it will work
Many people have done this set up here in Japan
i read about a hybrid accord brake caliper. integra or 4 door civic knuckle put together for ef`s. the accord calipers are same size as typeR calipers and disca are from a 5 lug prelude just drilled out to 4 lug .iy`s on hybrid web p[age
HATCHingMN
Feb 24, 2004 09:17 PM
