V-tec not poppin'...Why..??
Whats up guys...I was just wondering why v-tec ain't poppin' on my lude...?? The check engine light is on and i checked it already and it's throwing out the tps and ignition coil....is that why v-tec ain't turning on...??? Thanks...
yeah i just did an oil change 3 days ago..., but the solenoid i haven't yet...how can you tell if it's the solenoid..??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Search Results »</TD></TR><TR><TD CLASS="quote">Your search for vtec not engaging returned 39 results.
You have to click on the "Archived" option when you search.
DP said it right.
your car is in limp mode to keep you from doing something stupid
Check your Vtec Selonoid connections (Green plug near distro)
Then check what your CEL code tells you to....I dont know how straight forward this can be
if not, smash your head onto your desk until something useful comes out
theres ALOT of misinformation in this thread.
Vtec will engage with the CEL on, just depends on which CEL it is.
you are not in limp mode. REAL limp mode is pretty rare. Its when the car will not rev above 3000 rpms and you have a solid CEL.
I never knew there was an ignition coil cel...?? without an operating coil, the engine would never start since it is what supplies the spark.
and where did you get that these two cel's are usually the causes to vtec not engaging? i think you need to practive what you preach and do some searching/research on your own.
If you have access to a multiemter, you can test your TPS sensor. put the black end of the multimeter to the chassis or some ground and put the red end into the signal pin on the harness. It should read ~45volts closed and approximately 5 volts at WOT.
Go to autozone and have them check the codes because i dunno where you got ignition coil from.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B.Rabbit »</TD></TR><TR><TD CLASS="quote">theres ALOT of misinformation in this thread.
hey...at least i said "i think"
I was still partially right
You didn't read what i said B. Rabbit...thats the reason i posted this up cause i don't know why v-tec aint working..I never said because of those 2 problems i have...I just said what codes it was throwing and then i said if this is why...????
about the ignition coil..I just said that cause my friend checked the codes and he told me that it was throwing the ignition coil...so i don't know...oh you know what i think he said it was code 15 ignition output signal...what is that..???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm92lude »</TD></TR><TR><TD CLASS="quote">You didn't read what i said B. Rabbit...thats the reason i posted this up cause i don't know why v-tec aint working..I never said because of those 2 problems i have...I just said what codes it was throwing and then i said if this is why...????</TD></TR></TABLE>
i know this. I wasnt directing everything i said toward you.
go to autozone and have them run the scanner on it.
limp mode is a solid CEL. the ecu is supplied with a baseline fuel map that IIRC just dumps a shitload of fuel (likely retards timing) and drops the rev limiter to 3k. You can't even drive the car in limp mode. Trust me....i have tried, lol...theres just no power.
here's an example of limp mode.
you have a chipped OBDI ecu. You take the chip out and start the car. That is an example of true limp mode.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMhondalude22 »</TD></TR><TR><TD CLASS="quote">my cel is on and i still have vtec</TD></TR></TABLE>
me too
me too
Here is simply the best write up on Vtec problems you will find, and guess what ? It's in the FAQ near the top
https://honda-tech.com/zerothread?id=830163
shoot my veetak aint poppin either...wait maybe its V-tec...or VTECH...no...****...oh well i just know it aint poppin like it should be...you know...kinda like if you hit NAWZ...and you get pushed back into your seat...why aint my veetak doing that?
