Rebuilding a Blow Off Valve???
Pic of BOV in question:
A friend of mine has a Greddy blow off valve on his Eclipse GSX, and today he tried to tighten it up with the adjusment nut/screw, and it just spins like the screw is stripped somehow...
I know nothing about how BOV's work, but I was wondering if it can be rebuilt in any way to fix it?
I told him to get it home, take it off, and try taking it apart and seeing if something has come loose inside...
Thoughts on this??
Thoughts on this??
get a better bov. i have seen the greddys time over time fail and allow comperssor surge. TIAL 50mm > *, i had an hks and was getting slight compressor surge at around 25-30psi so i switch out to a tial
The motor is stock for now, so I don't think he's running 25-30psi, and there's no budget for a "better one"... But that really didn't answer the question...
Can these be rebuilt or fixed???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy »</TD></TR><TR><TD CLASS="quote">tap it for the next size up, and use a bigger bolt. problem solved</TD></TR></TABLE>
