1992 Acura Integra GS-R
Old Jan 6, 2007 | 04:12 PM
92integraVTECgsr's Avatar
Default 1992 Acura Integra GS-R
$6000 obo
(Actual GS-R. Check the VIN DB2. I sold the B17 engine)
Tons of NEW Parts:
JDM B16 XSi 170hp Engine swap from Hmotorsonline.com bought and Installed in May 2006.
52,000 miles on the Engine and Transmission
263,000 miles on the Body
New Matador Red Paint (2005 Nissan Altima SE-R Red) Aug. 28/06
There was and is NO RUST or BONDO anywhere on the car.
Rota Slipstreams (16 inch)
Kumho Ecsta SPT Tires September 5, 2006
New Parts when engine was installed in May 2006.
• OEM Honda Timing belt, water pump, tensioner
• Exedy Stage 1 Clutch
• Integra TypeR Flywheel (resurfaced)
• Hondata Intake Manifold Gasket
• OEM Honda Valve cover & spark plug seals
• Distributor Cap & Rotor
• NGK Iridium Spark Plugs
• OEM Honda Spark Plug wires
• Exhaust Manifold Gasket
• Energy Suspension Motor Mount Bushing Kit
• RS*R ExMag Full Exhaust
• Carsound 2.25 Catalytic Converter
• Radiator
• Failsafe Low Temp Thermostat
• Brand New Napa Axles (not Remans)
• OEM Honda Transmission Axle Seal
• NGK Oxygen Sensor
Parts replaced as of Jan. 1, 2006.
• DC Sports 4-2-1 Header
• Tokico Illumina 5-way Adjustable Shocks
• Goodridge Stainless Steel Brake Lines
• PBR Metal Master Brake Pads
• Duralast Front Rotors
• Momo Tuner Steering Wheel
• Tekniq Quick Release Steering wheel hub (Best you can buy!)
• Tekniq Steering wheel hub
• Acura Integra Floor mats (Logo)
• H4H Super White Bulbs
Oil & Filter Changed every 3000 miles with Mobil 1 10w-30
AEM Cold Air Intake
Skunk2 weighted Shift ****
Skunk2 Short Throw Shifter
Eibach Prokit Lowering Springs
JDM 1 Piece Headlights
Ingals Camber Kit
New Sony CD Player July 06
Sony 3 way Front Speakers and Pioneer 3 way Rear Speakers
Fuel Filter
Tie Rods
Upper and Lower Ball Joints
Polyurethane Shifter bushings
Ignition Wires and Switch
Speedometer Cable
Apline 200watt 4-channel amp and 10 inch Lanzar Sub. (Amp works on and off).
The car laid down 144.1 WHP but was told to add 13%, which comes to 162 WHP.
The engine DOES NOT burn or leak any OIL, or and other fluid. Only 93 Octane gas used.
Car is PERFECT! Nothing wrong at all. Pick up and drive anywhere! Very Clean!!!
Old Jan 6, 2007 | 04:27 PM
recap's Avatar
i dont even like DA's and i dont even like red... BUT that is REALLY nice... good luck maynnn.. BUMP
Old Jan 6, 2007 | 05:12 PM
Default Re: (recap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by recap &raquo;</TD></TR><TR><TD CLASS="quote">i dont even like DA's and i dont even like red... BUT that is REALLY nice... good luck maynnn.. BUMP</TD></TR></TABLE>
thanks
Old Jan 6, 2007 | 05:33 PM
Rahxephon's Avatar
Default Re: 1992 Acura Integra GS-R (92integraVTECgsr)
i've 93 GS-R your's 10X cleaner
Old Jan 7, 2007 | 04:29 PM
gotJDM-DAteg's Avatar
Default Re: (recap)
WOW, thats a very bold statement my friend. But yeah that car is F-ing sick yo. to another DA owner to bad your letting her go. You know you will regret it once you have sold it. I would if I sold my ride.
Old Jan 7, 2007 | 04:58 PM
Default Re: (gotJDM-DAteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotJDM-DAteg &raquo;</TD></TR><TR><TD CLASS="quote">WOW, thats a very bold statement my friend. But yeah that car is F-ing sick yo. to another DA owner to bad your letting her go. You know you will regret it once you have sold it. I would if I sold my ride.</TD></TR></TABLE>
I know
ILoveJDM.
Feb 6, 2010 08:48 PM
92integraVTECgsr
Jul 21, 2007 01:23 PM
92integraVTECgsr
Southeast (Sales)
Jun 29, 2007 09:19 PM
92integraVTECgsr
Mar 29, 2007 03:01 PM
92integraVTECgsr
Southeast (Sales)
10
Feb 18, 2007 05:54 PM
