h23 pistons fit h22 rods
my h22 has blown ring landings from 10psi of boost, i can get some h23 pistons for cheap around here, will the h23 pistosn fit the rods and what would the CR be.
https://honda-tech.com/zerothread?id=1232811
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociv910 »</TD></TR><TR><TD CLASS="quote">my h22 has blown ring landings from 10psi of boost, i can get some h23 pistons for cheap around here, will the h23 pistosn fit the rods and what would the CR be.</TD></TR></TABLE>
yes, they will fit. BUT the h23 pistons IIRC have pressed in wrist pins and the h22's have floating wrist pins. I believe you could take out the rods and have a machine shop mod them to accept a floating wrist pin, if thats even necessary.
those pistons have a different compression height so the h23 pistons may sit slightly below the deck.
since your boosting this would be perfect to run more boost safely you compression might be 9:1 i am alittle unsure tho
H23A1LUDE
Mar 3, 2003 07:38 AM
