B18c1 Stock p72 Ecu Engine Codes Help
Old Jan 6, 2007 | 02:52 PM
cceinc's Avatar
Default B18c1 Stock p72 Ecu Engine Codes Help
I am running a stock b18c1 with a p72 ECU it is Obd1. I am getting map, IAT, TPS, IAC, and FI. All of the wires are in good shape. I have heard of problems with the stock intake manifold. Any info help.
Thanks
Old Jan 7, 2007 | 04:00 AM
god.loves.ugly
Guest
Posts: n/a
Default Re: B18c1 Stock p72 Ecu Engine Codes Help (cceinc)
pull off the IACV and clean it with brake fluid. see if that helps. get a voltage tester and test what the TPS is at....
Closed is .45-.50
WOT is 4.5-5.0
if I remember correctly.
as for the other codes I'm not sure.
Old Jan 10, 2007 | 10:52 AM
cceinc's Avatar
Default Re: B18c1 Stock p72 Ecu Engine Codes Help (god.loves.ugly)
Thanks i will try that.
Silverdrifter07
Engine Management and Tuning
Sep 13, 2016 12:18 PM
AaronGeisinger
Dec 16, 2010 01:26 PM
mario_pic
Jan 25, 2008 08:37 PM
jdm styles
Jun 28, 2007 03:53 PM
mugen97ek
Jul 18, 2005 06:50 AM
