GSR axle removal.. lower ball joint.
I have the lower ball joint loose. I have the axle nut off. Everything is loose. I cannot lift the axle rotor off of the lca. It will not budge. There are centimeters between the lower ball joint's gasket and where the lca attaches. Any ideas?
I have beaten the top of the lca like Tyson. It won't seperate. Do I need more room between the gasket and lower ball joint?
Even though you got it now but you can try this next time.
https://honda-tech.com/zero...age=1
It works like a charm.
Ali
Ali
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo »</TD></TR><TR><TD CLASS="quote">nice considering you dont have to remove the lower ball joint to replace the axle</TD></TR></TABLE>
I'm parting the entire car. 1994 GSR.
White_EG1
22
May 21, 2018 10:20 AM
erikiksaz1
Suspension & Brakes
Nov 2, 2008 05:10 PM
C_Rock77
Aug 27, 2008 11:19 AM
