Would this setup work?
I have a 90 Civic DX hatch. Would Function 7 LCA's and a G2 Teg sway bar work? My Civic never had a sway bar in rear from the factory. Anything I would need to drill out? Thanks!
https://honda-tech.com/zerothread?id=1146145
ST bar mounts regardless of LCA style since it has brackets to mount to the shock.
K Im pretty sure I am going f7 LCA's and ST rear sway bar.
Does the ST bar have a option on mounting? Can I actually mount it to the new LCA's instead of shock?? Would I need the optional adjustable endlinks?
Thanks guys
Thanks guys
i didnt find the ST bar made to even work with stock linkage location. it was made to fit the shock. maybe with F7's difference linkage positions its possible.
So worse comes to worse I could just hook the ST bar up to the shock location anyway. Does the ST bar come with something to hook into the shock location?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CWBETB »</TD></TR><TR><TD CLASS="quote">Actually does the ST bar come with the adjustable endlinks? Thats really all I need to know now, thanks guys</TD></TR></TABLE>
yes it does
yes it does
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CWBETB »</TD></TR><TR><TD CLASS="quote">So the ST bar mounts using the tow hooks and Shock?? Thats interesting, so it would work on a DX and Si?</TD></TR></TABLE>
Yes sir, ST mounts to the bottom of the shock so the F7 LCAs will work (the function 7 also has the correct mounting hole for the OE bar)
The endlinks are adjustable and may very possibly mount to the OE location on the F7s.
JMelt4
18
Apr 30, 2007 07:43 PM
GroundZer0 336
Sep 19, 2006 02:24 PM
2-7offsuit
50
Apr 25, 2005 04:41 PM
