LS turbo guys...which spark plug did you like better?
Old May 14, 2002 | 10:00 AM
93LSivic's Avatar
Default LS turbo guys...which spark plug did you like better?
Ok, since I was running lean I think Im gonna swap out the plugs for some new ones. Ive been turbo for about 1500 miles so far.
Currently I am running the ZFR7F-11's gapped at 32. But after using the search, I've found that Flamenco-T said to use BCPR7E's gapped at 30-32.
I only want to use NGK, screw the platinum and the Zex ****.
Which one have you had better luck with?
Open to recommendations......
Old May 14, 2002 | 10:07 AM
newsense's Avatar
New User
Default Re: LS turbo guys...which spark plug did you like better? (93LSivic)
I have used these religously for the past 2 years.
Old May 14, 2002 | 01:08 PM
FFDragger's Avatar
New User
Default Re: LS turbo guys...which spark plug did you like better? (newsense)
BKR7E's gapped at .30
Old May 14, 2002 | 01:27 PM
modvp's Avatar
Default Re: LS turbo guys...which spark plug did you like better? (FFDragger)
NFK ZFR6F11 (gapped at .30) for the past 2.5 years...B18B turbo.
sasinorm01
Dec 24, 2014 12:17 PM
silverb18
Mar 24, 2005 10:26 AM
silverb18
Mar 31, 2004 08:08 PM
InTeGrA B18b1
May 11, 2003 12:26 PM
GettaluvR
Nov 24, 2002 12:31 PM
