Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Safe lowering level
Old Jan 6, 2007 | 10:03 AM
Ficky's Avatar
Default Safe lowering level
SO i have a set of 215/40R17's which i have yet to get tires on, but I know i will need to lower my car. What would be a safe drop where i wont rub, or scrap. I live in an area with LOTS of BIG potholes and speed bumps. Im looking at Dezods Suspension package stage II. Any help would be greatly appriciated. Thanks
Old Jan 6, 2007 | 11:23 AM
Vantage's Avatar
to be safe, id only go 1.5" tops, but im sure with a little work u could push 2".
Old Jan 6, 2007 | 12:04 PM
Curiouz_G's Avatar
depends if you have an aftermarket exhaust too. i know for my greddy evo II that 1.5 will rub on speedbumps if i dont be careful.
Old Jan 6, 2007 | 04:34 PM
Vantage's Avatar
pretty much any exhaust on em2's rub. It's just the bad way they made the exhaust.
Old Jan 6, 2007 | 04:43 PM
cherryhatch00's Avatar
1.5" is safe. 2 is pushing it. Maybe with bigger rims/tires you can do it, but then you MAY have to roll your fenders..
That's only if you go huge though.
Old Jan 7, 2007 | 02:57 AM
Synapz's Avatar
1.5" is probably the best... 40 series tires + bad roads = bad choice
Old Jan 7, 2007 | 07:11 AM
toyomatt84's Avatar
Sanji
The rims are the deciding factor in this argument. You won't be able to fit the tires past 1.5" if you're running an offset higher than +47 or lower than +40.
Old Jan 7, 2007 | 10:10 AM
Newborn_'s Avatar
Grace Under Pressure
True... i'm on a 205/17 +42 and it's pretty close to the arches even though i'm not decked. (I'm lowered about 50-55mm ish)
ElementzofR
Jan 26, 2009 09:16 AM
Change Me
Apr 14, 2007 07:16 PM
immalooser
Oct 2, 2003 10:13 AM
Acura_I-RS
Mar 15, 2002 03:17 AM
ajbones
Dec 20, 2001 08:56 PM
