Urgent! Questions before buying?
Old Jan 6, 2007 | 09:59 AM
cbmprelude's Avatar
* B A N N E D *
Default Urgent! Questions before buying?
A 94 accord wagon I looked at has a broken antenna. Can it be replaced with say an fixed rubber generic s2000 short antenna and still get reception? Will it get worse reception because it is partially blocked by a window?
Also the motor makes a slight ticking noise, it is an f22. What could this be?
The A/C took a while to get cold, maybe 20-30 seconds, but then it was pretty cold, why is this? Is this common?
Thanks
Old Jan 6, 2007 | 05:47 PM
02 accord's Avatar
Default Re: Urgent! Questions before buying? (cbmprelude)
Antenna: should work.
Ticking: do a valve lash adjustment.
A/C: no idea, haven't used mine in a long time.
Old Jan 7, 2007 | 08:11 AM
skingfreak's Avatar
Default Re: Urgent! Questions before buying? (02 accord)
antena: yes should get pretty go reception
Ticking: Might be a slight knock? in which case steer clear
A/C: Might need recharging you can get a kit for $30 to accomplish this
GL
Old Jan 7, 2007 | 08:17 AM
cbmprelude's Avatar
* B A N N E D *
Default Re: Urgent! Questions before buying? (skingfreak)
thanks, could I take it to a dealer to look at the motor to determine what it is? Would a honda dealer do this?
Old Jan 7, 2007 | 09:05 AM
gulfview's Avatar
Yes, a dealer would be happy to do it for good $$$.
While you are at it, you may want to have an engine compression test done as well -- it would tell you if the engine is still in good shape or not.
Good luck!
Old Jan 7, 2007 | 12:15 PM
Blamm!!'s Avatar
Default Re: Urgent! Questions before buying? (gulfview)
My accord had a ticking sound till I had the valve clearance adjusted. If it was a knock it would be more than ticking.
Old Jan 8, 2007 | 02:11 PM
skingfreak's Avatar
Default Re: Urgent! Questions before buying? (Blamm!!)
i was just throwing that out there as a possibility
mxteam
Aug 10, 2007 09:20 AM
shivsharma6
Apr 16, 2004 05:39 PM
Ben-VTEC
Feb 28, 2003 10:55 PM
TypeRod
Nov 29, 2002 08:45 AM
distuRbed
May 16, 2002 08:45 AM
