Which header to use on the swap....
Old Jan 6, 2007 | 07:37 AM
Mikes2000civicsi's Avatar
Default Which header to use on the swap....
i got a 01 gsr in a 99 si, are all b eries interchangeable,like a gsr header and a si exhaust...and other way around
Old Jan 6, 2007 | 10:32 AM
gezzuzz's Avatar
Default Re: Which header to use on the swap.... (Mikes2000civicsi)
the flange from the header will reach your cat but the bolts may be off.. at a different angle.. you can get you exhast cut and rotated for it to fit.. find some small muffle shop to do it for $20-30..
Old Jan 6, 2007 | 03:47 PM
Hybrid-Fusion's Avatar
Not sure on this one. Did the header lengths change when Honda converted to OBD2?
Old Jan 6, 2007 | 04:19 PM
gezzuzz's Avatar
Default Re: Which header to use on the swap.... (Hybrid-Fusion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid-Fusion &raquo;</TD></TR><TR><TD CLASS="quote">Not sure on this one. Did the header lengths change when Honda converted to OBD2?</TD></TR></TABLE>
no it didn;t but the angle if the flange is different
bonylad
Dec 25, 2005 04:51 PM
pootie.teng
Apr 14, 2005 11:53 PM
GIANT
33
Jan 28, 2005 01:13 PM
S@nt0s
Apr 25, 2004 05:28 AM
