Ok what engine is this?
Old Jan 5, 2007 | 10:05 PM
jeezyskillz's Avatar
Default Ok what engine is this?
So I just picked up another rex tonight and it has a dual (D16A8) motor what year is it and where did it come from?
Old Jan 5, 2007 | 10:16 PM
24TEN's Avatar
PHANTOM MENACE
I can't say for sure, but if I remember correctly isn't the D168/9 euro spec ZC? Can anyone confirm?
Old Jan 5, 2007 | 10:17 PM
djphonics's Avatar
Default Re: (24TEN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN &raquo;</TD></TR><TR><TD CLASS="quote">I can't say for sure, but if I remember correctly isn't the D168/9 euro spec ZC? Can anyone confirm?</TD></TR></TABLE>
Found in the EDM Honda Concerto 1.6l and Rover 219/419.
Old Jan 5, 2007 | 10:19 PM
24TEN's Avatar
PHANTOM MENACE
Awesome, I'm not that forgetful LOL
Old Jan 5, 2007 | 10:21 PM
so it's basically a euro ZC??? what is different from the japanese ZC?
Old Jan 5, 2007 | 10:25 PM
djphonics's Avatar
Default Re: (jeezyskillz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeezyskillz &raquo;</TD></TR><TR><TD CLASS="quote">so it's basically a euro ZC??? what is different from the japanese ZC?</TD></TR></TABLE>
Yeah. I don't believe there are any differences. If it's on the Rover, it will have an ugly valve cover with stripes that says "16V". If it's on the Concerto, the valve cover looks the same as the jap DOHC ZC.
Old Jan 5, 2007 | 10:28 PM
yup exactly right it says dohc 16 valve with stripes.....................so there is no difference then? compression and everything is the same?
Old Jan 5, 2007 | 11:51 PM
djphonics's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeezyskillz &raquo;</TD></TR><TR><TD CLASS="quote">yup exactly right it says dohc 16 valve with stripes.....................so there is no difference then? compression and everything is the same?</TD></TR></TABLE>
I'm pretty sure they are the same. I think the only differences are whether or not they were originally run with a Cat or not, which will change their listed power ratings. The A8, A9, and ZC should all be 9.5:1 compression and use the P29 piston.
Old Jan 6, 2007 | 07:57 AM
jlicrx's Avatar
Default Re: (djphonics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djphonics &raquo;</TD></TR><TR><TD CLASS="quote"> The A8, A9, and ZC should all be 9.5:1 compression and use the P29 piston.</TD></TR></TABLE>
actually, 88-91 DOHC ZCs use a PM7 piston - 88-89 Integras and OBD1 DOHC ZCs have the P29 pistons
Old Jan 6, 2007 | 10:36 AM
NorthstaR's Avatar
good info
Old Jan 6, 2007 | 11:12 AM
djphonics's Avatar
Default Re: (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">
Is there even a difference between the PM7 and P29 pistons? They look the same to me.
Old Jan 6, 2007 | 11:38 AM
vtec8200's Avatar
There is no difference between the pm7 and the p29's.
civic_frank
Aug 16, 2008 11:14 PM
jdm_dc_fan
Sep 5, 2007 07:58 PM
highriskZc
24
Sep 13, 2005 09:43 PM
JapJunkie
19
May 5, 2004 09:10 PM
tpr
Oct 23, 2003 09:37 AM
