euro members who have 18° ignition timing...
Well, I don't know where to get 99+ fuel? 98 RON should be good enough because it's within factory specs....
You can safily advance it. MY workshop manual say 16 degrees +/- 2 degrees. 98 or 99 octane should not matter. When you want to know it 100% exact, why don´t you go on a dyno do a run with 16, 14 and 18 degrees and look if something happens. It is possible that you lose power, when you advance it to 18.
My butt-dyno says I gained a bit. Not much.....
[Modified by austrian type-R, 7:22 PM 5/14/2002]
Be careful with 18º.
Even with 98 octane you might have some detonation.
If you´re running high compression pistons retard it to 14º.
I had a bad experience on that.
Pinota
Pinota
did you continue to use 98 oct or is it better to use 99+ oct?
ive done 20 degrees on 92 octane on 11.2:1 CR. I did how ever add some touluene so maybe it was around 94 octane
T-RO
May 16, 2006 05:26 AM
OzzieAccord
Jun 12, 2003 05:24 AM
sytema
Feb 12, 2003 10:51 AM
