lowering questions....helps
hi my friend got some lowering spring from ebay and he not using it....so he let me put it in my car....but is it true when you install those spring u also need a camber kit to keep the tired straight....is it neccessary for a camber kit when lowering the car....
here the pix of the spring....http://cgi.ebay.com/ebaymotors/94-01...69755785QQrdZ1
^ agree with what was said
you should get a camber kit, it is not needed though. however, your camber will be way off, tires will wear very fast, as well as possible adverse steering problems.
and those are not def not a good set.
EJ6_Sedan
26
Mar 5, 2008 06:21 PM
RWD_RCKT
Mar 23, 2006 01:15 PM
