rain gutters
no my house is good, but i'm going to repaint my car. i know where to get new ones. i just need to know i can just pry them off or do i have to drop the headliner, yuck! here a pick of the bay. Thanks in advance! here is a project link if anyone cares https://honda-tech.com/zerothread?id=1460407
i removed mine by pulling up and it's now bent.
the roof moulding consists of a metal strip coatd with rubber. pull up and the moulding will get bent and the moulding clips will be trash.
looks like the safest way to remove them is to gently pry them up in the rear and pull it straight out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 »</TD></TR><TR><TD CLASS="quote">
looks like the safest way to remove them is to gently pry them up in the rear and pull it straight out. </TD></TR></TABLE>
thats what I did and they came out fine. just pry up a bit in the back and then pull it slides right out, also make sure no windshield glue is holding it on in the front under the windshield molding.
so the clips are in the body and rhe rubber mouldings just slide into them? and big thanks!!!!!!
oh and i'm pulling out the windshield would it be better to pull them forward or back out the rear?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb »</TD></TR><TR><TD CLASS="quote">so the clips are in the body and rhe rubber mouldings just slide into them? and big thanks!!!!!!
yes the clips are in the gutter covered with seam sealer and the moulding slides into them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb »</TD></TR><TR><TD CLASS="quote">oh and i'm pulling out the windshield would it be better to pull them forward or back out the rear?</TD></TR></TABLE>
i'd pull them out from the front. it's possible to bend them while prying up so i'd rather have it bent in the front. that way maybe the windshield moulding could cover it up. no room for error when prying up the rear.
cadillacon22s
Paint and Body
Jun 29, 2007 06:50 PM
MysteryWagon
Apr 15, 2003 01:15 PM
