DOHC ZC owners ... Crank Angle Sensor same as Cam Angle Sensor?
Old Jan 5, 2007 | 03:16 PM
thenick's Avatar
Default DOHC ZC owners ... Crank Angle Sensor same as Cam Angle Sensor?
In all my research it seems there's no definitive answer. My question is: after my MPFI/ZC swap I'm getting a code 4 for Crank Angle Sensor. Am I looking at the dizzy or am I looking at the thing next to the distributor; the exhaust cam angle sensor? Thanks in advance.
Old Jan 5, 2007 | 03:25 PM
mengy007's Avatar
Default Re: DOHC ZC owners ... Crank Angle Sensor same as Cam Angle Sensor? (thenick)
*edit 4 usually means either the wiring to the distributor is wrong or the intake cam gear is off a tooth or so
Old Jan 5, 2007 | 03:29 PM
mengy007's Avatar
Default Re: DOHC ZC owners ... Crank Angle Sensor same as Cam Angle Sensor? (mengy007)
try switching the two cam angle sensor wires
Old Jan 5, 2007 | 03:31 PM
thenick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mengy007 &raquo;</TD></TR><TR><TD CLASS="quote">try switching the two cam angle sensor wires</TD></TR></TABLE>
Yeah that's what my friend told me today too... will anything catastrophic happen if I switch B10/B12?
Old Jan 5, 2007 | 03:33 PM
mengy007's Avatar
just depin on the plug that goes to the distributor it's easier anyhow.
*edit, I've done it before and nothing happened, but try it at your own risk.
Old Jan 5, 2007 | 06:21 PM
yeah i had the same problem
you gotta swap the wires..
I think its the orange/blue one but I will check when I get home
what ECU wiring diagram did you use
Old Jan 5, 2007 | 06:52 PM
civhatch90's Avatar
why are you gambling with the wires if you have the wire scheme above?
just make sure the orange one is by the empty slot, thats it.
Old Jan 5, 2007 | 08:23 PM
mengy007's Avatar
Default Re: (civhatch90)
If your timing is right then it has to be the wires unless you have a bad distributor
Old Jan 6, 2007 | 08:19 AM
jlicrx's Avatar
code 4 is for crank sensor in the distributor - the sensor on the exhaust cam is the Cylinder Position Sensor and if bad (which almost never happens) you will get code 9 - code 4 usually means you have a bad distributor - the picture posted above is one that i came up with and is for the Si/HF distributor connector, not the DOHC ZC - the DOHC ZC distributor connector is the same as the DX/LX/STD connector, like this:
Old Jan 6, 2007 | 08:26 AM
thenick's Avatar
Default Re: DOHC ZC owners ... Crank Angle Sensor same as Cam Angle Sensor? (jlicrx)
Woops. I removed it so as not to confuse anyone.
Old Jan 6, 2007 | 08:29 AM
jlicrx's Avatar
i edited my post to show correct connector
votex5
Jun 14, 2013 11:52 AM
h22_crx
Mar 19, 2006 12:18 PM
messeduprex
Apr 7, 2005 03:50 PM
99sonicbluegsr
Mar 23, 2005 10:36 PM
