what gasket to use or is this possible? lmk
i have an ls intake manifold off of a 94, but no throttle body. i purchased an SI throttle body, i was wondering if this is possible and if so, which throttle body gasket should i use for this?
si throttle body on an ls intake manifold...should i use the si throttle gasket or ls throttle gasket? confused on that part, it would be great to get the correct info cause that is all i need left in order to get my ls motor running. lmk thanks!
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
i would just go with the SI i think the LS TB is 60mm and a SI is 58mm but the the SI gasket should be fine
