Steering wheel locked wont start
Old Jan 5, 2007 | 11:52 AM
JamiAaryn's Avatar
Default Steering wheel locked wont start
I have a 1996 Accord LX. The steering wheel is locked tight and WILL NOT move. We have tried everything. The key in the ignition will not move either. Yes I have tried moving them together with tremendous force. Nothing. What can I do besides have it towed in and looked at by a mechanic?
Old Jan 5, 2007 | 01:52 PM
TheMuffinMan's Avatar
He knows where you live!
you should just have to move the steering wheel to the right or to the left just a little bit and it'll go
Old Jan 5, 2007 | 01:54 PM
jimjonez
Guest
Posts: n/a
Default Re: Steering wheel locked wont start (JamiAaryn)
dude i would NEVER use "tremendous force" if my key and steering wheel is locked? are you notz? what will you do if your key breaks in the ignition..... this has happen to me before.... all you have to do is wwiggle the steering wheel gently and twist he key on/off simultaneously
Old Jan 5, 2007 | 01:55 PM
birdman123's Avatar
if u have a 5 spd check taking it out of gear and e brake down, stick ur foot out and rock the car back and forth. sometimes it makes the wheel turn a little more.
Old Jan 5, 2007 | 05:00 PM
mrhonda2u's Avatar
Default Re: Steering wheel locked wont start (birdman123)
there is a spring loaded force that needs to be pulled off steering lock and turn key at the same time pressure is relieved from lock.
kreeves
Jun 24, 2008 06:06 PM
FaK iTz JaSoN
Honda Civic (2001 - 2005)
14
Oct 10, 2007 08:40 AM
sillyboybmxer
12
Jul 10, 2007 10:57 PM
jagged4698
Jan 23, 2004 11:26 AM
