Some ZC ?'s again
Okay Im getting ready to buy a ZC prob. in a month....
I have a 90 DX...but I have a 90 SI ecu, 90 Si harness, I could have the tranny but the 90 si is totatled and would be a bitch to take out unless I can drop it down from the engine without removing the whole engine?
What else should I use...
I have:
90 si ecu
90 si harness
stock dx tranny, shift linkage, axles
then a ZC motor.
Is that all I need?
I have:
90 si ecu
90 si harness
then a ZC motor.
Is that all I need?
You can pull the tranny from the bottom. As far as what else will you need. The only things I can think of are the down pipe and the intake tube. Most ZC's don't come with the down pipe. The ZC has a 4-2-1 design which is not compatible with the stock downpipe. The ZC will not need as long an intake tube as the DX. Of course it is always a good idea to do a complete tune up on the engine as well.
