Acura cl 2.3l motor in a 1998 accord??
Old Jan 5, 2007 | 08:31 AM
716pro's Avatar
Default Acura cl 2.3l motor in a 1998 accord??
I just brought a 98 accord EX ULE, I can get a very good deal on a spare motor from a 1998 2.3l CL Vtec. Is this basically the same motor or what. I know my accord says ULE Vtec on it and the CL motor just says Vtec, are they the same or different???
Old Jan 5, 2007 | 10:31 AM
philadd's Avatar
Default Re: Acura cl 2.3l motor in a 1998 accord?? (716pro)
They are pretty close to the same thing. If your Accord had not been the ULEV motor, than you would have the same one from the 2.3 CL.
Old Jan 5, 2007 | 11:09 AM
716pro's Avatar
Default Re: Acura cl 2.3l motor in a 1998 accord?? (philadd)
Right, that what i figured. So what is neede to swap the motors just ECU's?
Old Jan 5, 2007 | 03:18 PM
philadd's Avatar
I don't think anyone has actually confirmed it, but the ECU should be the only other thing you need. ULEV engines also have the different catalytic converter, but that shouldn't be an issue.
Old Jan 6, 2007 | 03:56 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">I don't think anyone has actually confirmed it, but the ECU should be the only other thing you need. ULEV engines also have the different catalytic converter, but that shouldn't be an issue.</TD></TR></TABLE>
watch out for the heated sensor for the ULEV model, they freaking expensive and theres not aftermarket replacement
you have to check, i think the late model cl do have chipped's key and ecu
if the ecm/ecu doesnt has immobilizer, you have to program your chip/key in order to crank start
Old Jan 6, 2007 | 04:27 AM
YeuEmMaiMai's Avatar
i dont even think you need a new ecu unless you are swapping into a DX
Old Jan 6, 2007 | 07:22 AM
716pro's Avatar
Default Re: (YeuEmMaiMai)
Good info, I will look into it a little further. Thanks.
Artv
Jan 10, 2008 04:33 AM
94c1v1cex
Aug 21, 2007 10:24 PM
qcoffey
Mar 26, 2004 11:00 AM
S13 slide
Feb 4, 2002 08:19 AM
