VTEC solenoid gasket for B18C1
Old Jan 5, 2007 | 05:47 AM
guttedEF's Avatar
Default VTEC solenoid gasket for B18C1
My B18C1 is leaking oil from the VTEC solenoid gasket. The cam seals are new and aren't leaking for sure.
My questions is, is the gasket for an '01 B18C1 the same part as for say a '99-'00 B16A from an Si. I went to get the part from the Honda dealer and the parts guy told me that he can't look up Acura parts and I need to go to an Acura dealer, but the closest one to me is like 30 miles away. I'm hoping it's the same so I can get this thing fixed.
It also needs spark plug tube seals, but I'm sure those are the same as other B-series engines, since the valve covers are all interchangeable. Well on DOHC VTEC ones that is. Someone correct me here if I'm wrong.
Thanks in advance for the help guys. I did a search and found nothing..
Old Jan 5, 2007 | 05:50 AM
djsire's Avatar
Default Re: VTEC solenoid gasket for B18C1 (guttedEF)
tell him you need them for a b16 del sol.
its a honda!
or just order them online
Old Jan 5, 2007 | 05:54 AM
guttedEF's Avatar
Default Re: VTEC solenoid gasket for B18C1 (djsire)
I figured this much..
I saw when I searched that the OBD0 gaskets were different. I just didn't know if being an OBD2 engine the gasket was any different.
Thanks for the quick response..
rpk1002
20
Dec 9, 2011 01:21 PM
kc_kc
Dec 23, 2010 07:58 AM
Moi Zver' (GSR)
Dec 3, 2009 01:17 PM
twinj
12
Apr 18, 2007 06:44 AM
type Gendy
Apr 2, 2003 02:17 PM
