Accord eats lightbulbs
Had the same problem on my 00 accord v6 i had the car for one year and went through 5 sets off bulbs. you have to make sure you dont touch the bulb upon instal and also get the same wattage as stock ones
hows your headlights housing?
things like that can happend when you get water and dirt in there causing the lights to die faster.
i go through 3 sets a year cause my right headlight has this 2 inch hole in it.
def check to see if its sealing correctly and that you dont touch it.
how often do you use your lights? every night?
if you have doubts that it is sealing correctly put an extra rubber seal from one of the old lights on too.
nicolaselias
Aug 5, 2008 02:31 AM
jneusch
Jan 30, 2008 06:22 AM
weakGOODJunKieS.com
Aug 16, 2003 01:33 PM
