2000 civic getting horrible gas mileage
Old Jan 4, 2007 | 10:12 PM
justseeingifitistaken's Avatar
Default 2000 civic getting horrible gas mileage
it is a 2000 ex civic coupe and i literally got 200 miles to the tank. i just got it and it does have a CEL i counted and i think it is 43, which is fuel system. what exactly is that? i found the codes but it doesnt exactly explain this cel. i checked it another time after i reset the ecu and got one blink which is 02 but which o2? things are a lot different for me coming from a ton of EFs to this. thanks
Old Jan 5, 2007 | 12:14 AM
Default Re: 2000 civic getting horrible gas mileage (hondaJDMimports)
bump
Old Jan 5, 2007 | 12:28 AM
The_Todd's Avatar
Farts in the shower
Well first off you need to post the code you got, please don't reset the ecu.
Without knowing for sure what codes it's throwing it sounds like secondary o2 sensory is going out, could use some new plugs/plug wires, clean air filter and an oil change though.
Old Jan 5, 2007 | 12:55 AM
Frozen E's Avatar
H-T White Ops
Take the car to auto zone or checkers and have them pull the actual code. Counting blinks is fine for some stuff. Actually hooking a scanner up and getting them to pinpoint the problem is the only way to go.
It's FREE!!!
::edit::
Saw you're in Honolulu. Take your car down to the Checkers next to K-Mart by Aloha stadium. They'll give you a printout and everything.
Old Jan 5, 2007 | 01:07 AM
Default Re: (IslandSi)
hmmm...didnt know they did that. on obd0 counting is perfectly fine, never had a false reading yet. obd2....different story I assume. there were so many blinks and some longer than others...i'll take it to checkers. mahalo
Old Jan 5, 2007 | 01:09 AM
Jimmy's Avatar
Global Moderator
Default Re: (hondaJDMimports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaJDMimports &raquo;</TD></TR><TR><TD CLASS="quote">hmmm...didnt know they did that. on obd0 counting is perfectly fine, never had a false reading yet. obd2....different story I assume. there were so many blinks and some longer than others...i'll take it to checkers. mahalo</TD></TR></TABLE>
One long blink is 10 and each quick blink is 1.. Goodluck
and if your throwing a CEL for O2 sensor, this is most likely going to be the culprit for bad gas mileage.. aside from a tune up.
Old Jan 5, 2007 | 01:13 AM
Default Re: (Jimmy)
i havent even taken a look under the hood really yet. where is the secondary o2? on the exhaust manifold or closer to the cat? like i said i havent looked yet, just guessing.
Old Jan 5, 2007 | 01:23 AM
Frozen E's Avatar
H-T White Ops
secondary O2 is after the cat. Primary will be after your header close to the inlet of the cat.
Old Jan 5, 2007 | 02:22 AM
inspireAZN's Avatar
wtf i drive a 97 civic 4 door lx and get around 190-200 per tank which is like 8 gallons o_o
Old Jan 5, 2007 | 02:27 AM
The_Todd's Avatar
Farts in the shower
Default Re: (inspireAZN)
I'm boosted and get 300+ miles on 8-10 gallons of gas LOL!
to be you = sucks!
Old Jan 5, 2007 | 02:28 AM
Frozen E's Avatar
H-T White Ops
My 94 EX gets around 230 per tank. At that point I fill up with about 9 gallons. So about 24 mpg.
Old Jan 5, 2007 | 05:07 AM
sql_civic's Avatar
It could also be a bad fuel pump. You didn't say how many miles are on your car. When mine went bad, so did the gas mileage.
Besides a basic tune as suggested earlier, be sure to adjust your idle and timing.
Another consideration is to have your injectors cleaned. You can either send them out or dump some Chevron Techron in your gas tank or Seafoam into your intake.
Old Jan 5, 2007 | 06:21 AM
Hybrid96EK's Avatar
Default Re: 2000 civic getting horrible gas mileage (.ken)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ken &raquo;</TD></TR><TR><TD CLASS="quote">Well first off you need to post the code you got, please don't reset the ecu.
Without knowing for sure what codes it's throwing it sounds like secondary o2 sensory is going out, could use some new plugs/plug wires, clean air filter and an oil change though.</TD></TR></TABLE>
Secondary O2 will have no effect on gas mileage other then the CEL he gets from it... In other words, its not going to cause much problems if it were to fail. The primary O2 however WILL cause a drastic decrease in mileage. Code 43 and a Code 1 = Primary O2 took a crap on you.
Old Jan 5, 2007 | 08:23 AM
Nameless Warrior's Avatar
Default Re: 2000 civic getting horrible gas mileage (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ken &raquo;</TD></TR><TR><TD CLASS="quote">I'm boosted and get 300+ miles on 8-10 gallons of gas LOL!
to be you = sucks!</TD></TR></TABLE>
How in the motherfucking hell is that possible? I can understand 200...but 300+?! I called bullshit man or you're not calculating it right.
Old Jan 5, 2007 | 09:02 AM
D-Rizzle3's Avatar
I get right around 300 with my D15. Go get it scanned and find out the problem.
Old Jan 5, 2007 | 09:10 AM
allricedout's Avatar
it could also be that you have a heavy right foot. :/
Old Jan 5, 2007 | 10:23 AM
jtchinoy's Avatar
Default Re: 2000 civic getting horrible gas mileage (Nameless Warrior)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless Warrior &raquo;</TD></TR><TR><TD CLASS="quote">
How in the motherfucking hell is that possible? I can understand 200...but 300+?! I called bullshit man or you're not calculating it right.</TD></TR></TABLE>
It's easy to make stock mileage boosted if you stay in the boosted range minimally. Your car is essentially stock until your turbo spools up
Old Jan 5, 2007 | 10:44 AM
junior40er's Avatar
Default Re: 2000 civic getting horrible gas mileage (jtchinoy)
wow I fel sorry for ya. I get 410 miles on a 10 gallon tank.
Old Jan 5, 2007 | 05:44 PM
Default Re: 2000 civic getting horrible gas mileage (junior40er)
wow a ton of replies!! the thing is I am used to the 530 miles a tank on my rex for highway/380-400 city....so this is really bad for me. Also i did not drive with a heavy right foot, i try to drive to get the best gas mileage possible, that is what has stumped me? thanks for all the responses though, i am going to get the code officially deciphered and replace what needs replaced. also the car only has 49000 on it so i doubt fuel pump but you never know?
Old Jan 5, 2007 | 08:55 PM
Ok i went to checkers and got an obdII test and the result........P1706 TCM A/T Gear Position Switch Circuit Open.......what does that trash mean. they couldnt tell me at the store either. I looked it up and it says that it wont shift from 1st or 4th perfectly on its own, so it is stuck in either 2nd or third all the time....kinda makes sense from the gas i'm burning but it feels like it shifts fine. IDK anyone know how to fix? thanks
Old Jan 6, 2007 | 12:59 AM
jtchinoy's Avatar
new transmission?
Old Jan 6, 2007 | 03:45 AM
EE_Chris's Avatar
Code 1 and 43 go hand-in-hand with the primary O2 sensor, as Hybrid93 pointed out.
But what is this "stays in 2nd or 3rd..."? How can you not tell if your car is shifting correctly?
Old Jan 6, 2007 | 09:16 AM
Default Re: 2000 civic getting horrible gas mileage (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Code 1 and 43 go hand-in-hand with the primary O2 sensor, as Hybrid93 pointed out.
But what is this "stays in 2nd or 3rd..."? How can you not tell if your car is shifting correctly?</TD></TR></TABLE>
Thats just it the car seems as if it is shifting fine, thats why i am asking if someone knows exactly what this code is....if you google it you get this
P1706 means that the tranny fails to shift other than 2nd-4th gears and lock-up clutch does not engage.
the tranny every once and a while doesnt downshift correctlt, or actually downshifts too soon maybe not sure. anyone had this?
Old Jan 6, 2007 | 11:30 AM
ekKO's Avatar
A/T FTL...sounds like an internal tranny problem...could be a solenoid tho...what RPM's are you taching out at on highway speeds?
Old Jan 6, 2007 | 02:20 PM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
Secondary O2 will have no effect on gas mileage other then the CEL he gets from it... In other words, its not going to cause much problems if it were to fail. The primary O2 however WILL cause a drastic decrease in mileage. Code 43 and a Code 1 = Primary O2 took a crap on you.</TD></TR></TABLE>
Oops, must have gotten those mixed up I spose....but you're right, the o2 sensor on the header will cause mpg drops.
Well considering I live at 5300' above sea level and before I would get 240 miles on a tank but ever since I threw the snail on I've gotten better gas mileage. I'm thinking it's because I don't have to press on the gas as much to get going, that and my kewl tune . I'm not going to go around a damn forum making up miles per tank just to flex my e-***** so go ahead and stuff your "bs" flag.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtchinoy &raquo;</TD></TR><TR><TD CLASS="quote">
It's easy to make stock mileage boosted if you stay in the boosted range minimally. Your car is essentially stock until your turbo spools up </TD></TR></TABLE>
Boost is where it starts to eat fuel up...I can boost 1-2 psi with normal driving and get 300+ miles on a tank.
I just filled up and due to the snow and a lot of idling time (warming up) I got 270 miles on this tank.
