Bearings, Bearings, Bearings....
Old Jan 4, 2007 | 07:51 PM
SOHCD16y8's Avatar
Default Bearings, Bearings, Bearings....
I just need some quick info about Honda's B-series Main bearings sizes. I basically just need to know what colors represent what sizes. Like green equals 0.00mm oversize, so what does yellow, black, brown, etc mean?
Modified by SOHCD16y8 at 12:22 AM 1/5/2007
Old Jan 4, 2007 | 07:59 PM
swappedcx's Avatar
Default Re: Bearings, Bearings, Bearings.... (SOHCD16y8)
http://www.evans-tuning.com/tech1.html
exactly half way down....OR
https://honda-tech.com/zerothread?id=715490
Old Jan 5, 2007 | 08:22 AM
Finland's Avatar
I posted my little excel worksheet a while back, it will help you determine your bearing colors depending on desired clearance.
Your best bet is to measure, measure and measure. Then plug your numbers into the sheet and it will spit out your results.
If the motor is bone stock, and the crank has not worn beyond spec, then you can just use the original bearing colors.
https://honda-tech.com/zerothread?id=1494711
Old Jan 5, 2007 | 08:47 AM
SOHCD16y8's Avatar
Thanks very much, I usually just use all standard bearings from a brand called hi-tech and have always had perfect clearance. This has been working on about 8 motors now that I have built and they all never had a problem. This time I decided to try and use clevite 77 std all the way around (I usually use them on just the rods) and for some reason I have like.003 on all the journals. WHen I run the crank and block codes on the chart I get that I need 2 brown and 2 black and a yellow. THe yellow is what is bothering me, if the clevites are set to std green sizing then a yellow would make the problem worse. The only thing I can think of is that maybe the clevite are made smaller then the greens. I am going to take some more mearusement today and try to figure this out. Thanks again
karnieflk
Jul 13, 2008 07:21 PM
killerpenguin21
Jul 12, 2006 07:20 AM
92hatchattack
Jun 7, 2005 09:21 AM
