will 90-93 teg spindles fit on a EG?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">Nothing from a DA to an EG is a direct bolt up.</TD></TR></TABLE>
Rear disc brakes do. But fronts will not work because it will give positive camber.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkdog167 »</TD></TR><TR><TD CLASS="quote">ya they will fit, you need the arms and brake assemble, brake line, 40/40 prop vavle. Maybe me a master cylinder too. search which prop vavle you need.</TD></TR></TABLE>
are you sure???
are you sure???
Saw it some where, but forgot where on the web...Me and my bro went to junkyard, and they are the same thing, but i think you need newer integra prop valve. Not sure, never done it before, sorry.
my kyb shocks bolted straight up to my del sol....well i had to change the front a-arms but other than that they bolted up fine....
short shifters will also bolt up
bump for an answer for this...i have a da and an eg in my backyard...i'd love to strip my da down to bones and use as much as possible on my eg
yeah i'd like to get a for sure answer on it before i spend time pulling the stuff off....workin 60+ hours a week and going to school doesn't leave a whole lot of off time so if i have off time i dont want to spend it investigating to see IF something will work or not....
puertoricanboy90
11
Jun 21, 2011 02:42 PM
nefariousyellow
Sep 29, 2007 09:48 PM
TeggerLS
Sep 17, 2006 12:17 PM
