wont start
Old Jan 4, 2007 | 06:51 PM
Joey.'s Avatar
* B A N N E D *
Default wont start
i have a d15.. and i put a d16 head on it.. its a vtech head... everything is hooked up... but the car wont start.... i turn it over and the starter gose on and like in 3sec later it pops... and sounds like it is the pistons then like 3 sec letter it dose the same....? whats wrong with is? is it the firing ? or.....
Old Jan 4, 2007 | 06:55 PM
dr_latino999's Avatar
Default Re: wont start (Just Joey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Just Joey &raquo;</TD></TR><TR><TD CLASS="quote">i have a d15.. and i put a d16 head on it.. its a vtech head... everything is hooked up... but the car wont start.... i turn it over and the starter gose on and like in 3sec later it pops... and sounds like it is the pistons then like 3 sec letter it dose the same....? whats wrong with is? is it the firing ? or..... </TD></TR></TABLE> We need to work on your English ability Beyond that, did you do the OBD-1 conversion like you should? Are you sure the mechanical timing is on? Because if it isn't, your valves are being forced into your pistons which just doesn't make for a kosher motor.
Old Jan 4, 2007 | 07:02 PM
Joey.'s Avatar
* B A N N E D *
Default Re: wont start (dr_latino999)
OBD-1 whats that? i just did the head...
Old Jan 4, 2007 | 09:32 PM
civicgen4's Avatar
man ur not doing to well r u. obd1 obd0 ob2 that the type of ecu it is. every ecu is like a pm6 pm4 those r obd0, ur giong to have to get a obd1 ecu that was for the head, but ud probley be better off just getting a d16 block as well, and just doing the whole motor. but for starters u need that ecu and the jumper hassness for the ecu.
Old Jan 4, 2007 | 10:36 PM
Redline130's Avatar
What distributor are you using? What about the ecu? Do you have the sparkplug wires in the correct order? There is a lot of possible causes for your situation.
Joey.
Jan 4, 2007 07:06 PM
jDm-Ek9
Jul 22, 2005 01:23 AM
KingJeff
Dec 12, 2004 05:48 AM
Quade
Oct 21, 2004 07:55 AM
xkhalil333x
Oct 16, 2003 06:16 AM
