Zc axles and int shaft on Si trans?
Old Jan 4, 2007 | 06:41 PM
d16vtecx's Avatar
Default Zc axles and int shaft on Si trans?
I recently bought a set of zc axles and int shaft because i was supposed to be getting a zc trans, but that deal fell through. Now I can get a good deal on an Si trans. I have a sohc zc vtec motor that has the holes for the int. shaft. So my question is can i use the zc int shaft and axles with an Si trans?
Thanks
Old Jan 4, 2007 | 07:22 PM
Tyson's Avatar
Default Re: Zc axles and int shaft on Si trans? (d16vtecx)
short answer, yes if you had the DOHC diff ONLY, or the bigger side gears from a integra i think.
long answer, read this thread to understand why. (yes its the reverse of what youre asking, but its the same principle.)
https://honda-tech.com/zerothread?id=1793626
Old Jan 5, 2007 | 06:28 AM
jlicrx's Avatar
you will need a ZC differential carrier and side gears - the intermediate shaft will not fit in a DX/Si differential carrier - the hole that the axle goes through is too small
Old Jan 5, 2007 | 09:05 PM
d16vtecx's Avatar
Default Re: Zc axles and int shaft on Si trans? (jlicrx)
there aren't any integra diffs or side gears i could use? because i dont have much access to zc parts
and how would i go about changing the diff and side gears? I have never opened a trans so it is all new to me
thanks for the info
Old Jan 5, 2007 | 09:30 PM
dwerpk's Avatar
i herd that thoughs intermediate shaft are real hard to find...if this was easy it would help out so much on d16's
Old Jan 6, 2007 | 09:20 AM
d16vtecx's Avatar
Default Re: (dwerpk)
maybe bense or mista bone can chime in
BrayzieEF9
Jan 23, 2010 04:33 PM
loudes13
Jun 9, 2009 07:19 PM
tico
45
Sep 5, 2008 09:23 AM
ServiceAdvisor
Mar 23, 2005 12:22 PM
tdc
Feb 13, 2002 01:07 AM
