weird code on chipped p28
Old Jan 4, 2007 | 05:22 PM
ev13lf's Avatar
Default weird code on chipped p28
my buddy bought a 95 civic si with what is supposedly a gsr motor with a fairly worked head and a chipped p28. when he recieved the car it was running bad because the previous owner had put the wrong plug wires on it. just put new cap rotor wires plugs on and took it for a ride. the engine ran fine, however it was running piggy rich. half way through the ride the cel came on. turned out to be a 37, which is not a code so far as i know. i even double checked it to make sure it wasn't a 36. Anyone ever see this?
he's kind of worried that he's going to have to get a new ecu, i don't know what to tell him.
lemme know
thanks
Old Jan 4, 2007 | 05:29 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: weird code on chipped p28 (ev13lf)
never heard of a 37
Old Jan 4, 2007 | 05:36 PM
ev13lf's Avatar
Default Re: weird code on chipped p28 (Throwdown)
that's my point
is it possible that a bad ecu could throw weird codes?
i don't have any experience with chipped ecus, but im going to assume that this is weird and probably advise him to replace the ecu
Old Jan 4, 2007 | 05:40 PM
iredline2000's Avatar
Since its a chipped p28 you can cut the jumper wire in the ecu to make go to its stock way. I think its label j01 in the ecu.. and if the code goes away it might be a bad chip.
Old Jan 4, 2007 | 05:44 PM
ev13lf's Avatar
Default Re: weird code on chipped p28 (iredline2000)
gracias
Old Jan 4, 2007 | 06:12 PM
JSPECSIR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iredline2000 &raquo;</TD></TR><TR><TD CLASS="quote">Since its a chipped p28 you can cut the jumper wire in the ecu to make go to its stock way. I think its label j01 in the ecu.. and if the code goes away it might be a bad chip.</TD></TR></TABLE> exactly also it may be running rich due to the fact that a p28 does not have the outputs to open the butterflys on the second set of intake runners. it is capable however of delivering the fuel its supposed to get when they open, but they dont open, thus rich condition. just my .02 i could be completely wrong.
civic j
Jul 25, 2007 10:15 AM
95accordh22a
Apr 8, 2005 08:03 PM
SOHC_MShue
Nov 11, 2004 11:52 AM
B18C1 Civic EG
Jul 31, 2004 12:06 AM
Petah
May 5, 2003 07:48 AM
