Resistor Box install in '99 Civic EX
I have been reading up on a few useful threads about this install but looking at my driver's side fender area near the clutch fluid reservoir, I don't see a "Dead End" connector as referred to by a few of the threads.
Here's one thread...
https://honda-tech.com/zerothread?id=736737
Is this "Dead End" connector located somewhere else in my engine bay?
on the OBDII models, the "dead plug" or "dummy plug" is located under the intake manifold, not on the drivers side shock tower area like on OBDI cars
some people on the OBDII cars just grab the individual wires right there at the injector, run them over to the resistor box and then back to the injector
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">some people on the OBDII cars just grab the individual wires right there at the injector, run them over to the resistor box and then back to the injector</TD></TR></TABLE>
Thats what I did on my 99.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">on the OBDII models, the "dead plug" or "dummy plug" is located under the intake manifold, not on the drivers side shock tower area like on OBDI cars
is that you,mike?
back on topic, i just went through hell wiring in a resistor box in my 99-00 ek hatch. the dead-end plug is underneath the intake manifold. there are two dead-end plugs, however. you'll need to use the one with the 6 yellow/black wires and 6 solid black wires. be sure to check for continuity from the ylw/blk wires at the injector plugs and the ylw/blk wires at the dead-end plug. you'll use 4 out of the 6. the remaining two ylw/blk wires, twist them together and run them to the red wire coming from the resistor box. as for the remaining black wires, twist them together, apply solder and tape it out of the way. those black wires are grounds.
i made the mistake of following the obd1 wiring instructions to wire-in my resistor box and couldnt figure out wth was causing my fuses to blow.
btw, itll be ALOT easier if you pull your engine harness off of your engine to do this.
is that you,mike?
Get a thermal reusable intake manifold gasket. That's what I did and it made it less-painless to remove the intake manifold so many times. Hooking it up to the clips works as well.
So, by looking at this diagram, it seems to me that it is just way easier to get some bullet connectors and wire the resistor box directly to injectors as opposed to finding, checking for continuity and depinning the dummy plug under the intake manifold, right? It may not be a clean and stealthy as a dummy plug but it'll serve it's purpose.
That idea crossed my mind cuz I have a handful of 10ohm resistors laying around from my Electronics class but I bought a Chrom chipped p06 for VTEC, dsm 450s (blue tops) and a resistor box for $150. Might as well use the box cuz I have it.
Snail Tuning
Feb 3, 2005 07:17 PM
