Need HElp...
Im tired of seeing the tie strap wrap around the AC fan on the Aftermarket radiator.. Is this impossible to remove the AC fan with AC in my car? Does It will get overheat or damage the AC system? I need help... Is there anyway to hold the AC fan beside the crappy *** tie strap...
HEre is the pic:
PS.. The AC gold metal holder removed..
HEre is the pic:
I'd assume ya mean so that the zip ties up top wont show, but still keep the ac fan in place...
This is what ya need....just in case, the ties go through the fan mounting points in the top and bottom corners, and then through the radiator. They're kept from pulling back through via the 4 stoppers that go on the other side of the radiator.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thurman Merman »</TD></TR><TR><TD CLASS="quote">I'd assume ya mean so that the zip ties up top wont show, but still keep the ac fan in place...
DO u have any idea where I can get this?
Also I got the mssage from HOnda tech..
But without ac fan the air condition is still working when the car is not in movement? I mean the ac fan is not necessary at all for a good ac job?
Is it safe? If yes I will take the AC fan off because there is no way I can find something to hold the AC fan..
</TD></TR></TABLE>DO u have any idea where I can get this?
Right here is where you can get them..
https://secure13.nexternal.com...s.asp
Don't worry about removing the AC fan after you install it with these. YOu've removed the gold strap and won't have any zip ties on top of your radiator, you're golden with the look and still keeping AC
so all you want to do is remove the gold strap thing? if so just take it off, that hose is pretty firm its not gonna flop around or anything, if thats not what your lookin for then dissregard what i say lol
turbo Si
May 15, 2003 08:04 PM
turbo Si
May 15, 2003 03:48 AM
