Old Mar 31, 2015, 08:37 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Honda Accord Brake Guides
Print Wikipost
how often should I flush my brake fluid and bleed it ?
Old Jan 3, 2007 | 11:18 PM
redDAinteg's Avatar
Default how often should I flush my brake fluid and bleed it ?
Any input?
Old Jan 4, 2007 | 04:44 AM
redDAinteg's Avatar
Default Re: how often should I flush my brake fluid and bleed it ? (redDAinteg)
1+
Old Jan 4, 2007 | 07:07 AM
nsxtasy's Avatar
H-T Order of Merit
Flush - If this is only for street use, every 30K miles or 2 years, whichever comes first. If you use your car in autocross or track events, then any time you're at one of those events, your fluid should have been flushed within the previous 6-8 months.
Bleed - Only when you have problems (e.g. soft pedal).
Old Jan 4, 2007 | 07:40 AM
95 integra's Avatar
Default Re: how often should I flush my brake fluid and bleed it ? (nsxtasy)
Doesn't honda recommend doing it every 90k?
Old Jan 4, 2007 | 01:36 PM
DamnYank!'s Avatar
i like to do mine about once a yr to yr and a half.
i use a cooking baster to get all the old fluid out of the res, refill with fresh fluid (really like the Valvoline SynPower fluid), then bleed all 4 corners twice to get the new fluid down into the lines & calipers.
Old Jan 4, 2007 | 01:53 PM
nitrofish420's Avatar
I don't race or anything, but I flush my fluid every year or so. It's kinda overboard, but I'm sort of **** when it comes to fluid maintenance. I've got a Vacula vacuum bleeder at work, which makes the process a breeze. I just suck out the fluid from the M/C, refill with fresh fluid, and then bleed each corner with the Vacula for about 5 minutes or so to draw the remaining fluid out of the calipers and lines. I just use the generic DOT 3 fluid we've got at work.
Canucksfan101
Feb 2, 2015 10:05 AM
93CamaroLT1
Jun 20, 2006 06:48 PM
kornerk12
Dec 30, 2005 12:53 PM
kommon_sense
Jan 4, 2005 11:46 AM
speedymon
Aug 27, 2002 05:35 PM
